Two Questions for the veteran teeners, For those who've been there, done it wrong, and then did it again |
c12croft |
Jun 26 2011, 07:37 PM
Member Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
Easy for you 914 mavens.
For the street driver only, no competition track (means pretty but aggressive) 1. Fire Extinguishers--------which type is best? ie; halon, best mount, ie; floor, seat rails etc. OR in engine compartment automatic sys? 2. Battery quick disconnect ---------prevent storage drain. assuming battery is in original location on tray, which is best? "Key type" or terminal quick unscrew style (at batt terminal) AND best location for key switch (in cab dash? or on engine lid?) Bosch, or Rennline (with red key?) THANK YOU Attached image(s) |
iamchappy |
Jun 29 2011, 07:59 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I have the dash mounted fuel pump kill and ignition kill in case the fire appears while i'm driving, my steering locks with the ignition turned off.....just seems safer that way.....plus the on board fire system can start working before i exit the car.
In regards to fuel injection my system runs at 100psi (IMG:style_emoticons/default/w00t.gif) |
ArtechnikA |
Jun 29 2011, 08:01 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Lo-Fi Version | Time is now: 13th June 2024 - 12:38 AM |
