930 Trans, Could this be the one I want... |
wallys914 |
Jul 2 2011, 01:48 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I have been looking to purchase a 930 for my v8 conversion for a while, I know it will be pricey but it will come with the strength and longevity that will be needed for the power I want to put down.
These are the specs, anyone want to chime in? This should be the right type, right? What would be a reasonable price considering I will have to tear it down flip the R&P and other modifications? ( besides FREE) Per owner: The transaxle was purchased from a Porsche Transmission shop in LA, They completely went through it and it has not been used since. 930 (LATE-LONG BELL) TRANSMISSION SPECIFICATION • Type: 930Original equipment for: Porsche 3.3L 930, 911 Turbo 78-88 • Description: 4 speed manual transaxle, std H pattern • Limited Slip Differential • Weight (approx): 117lbs • Speedometer: electric/hall sensor • 1st gear: 2.25 • 2nd gear: 1.304 • 3rd gear: 0.893 • 4th gear: 0.625 |
BIGKAT_83 |
Jul 2 2011, 02:48 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I think you want a short bellhousing or you will have to machine it down. The R/P cannot be flipped in a 930. The entire tranny needs to be flipped and then oil hoses need to be machined into the sides/bottom for the oil to move around. Half right you do want the early short bellhousing 930. The ring gear can be flipped with a little machine work. I was qouted $300 for the machine work for the ring gear and shorting the bell housing of a late to early length 930 transaxle Bob |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:26 AM |
