> Introducing "Dirty Penny" - Former $2010[$2012] GRM Project, Running. Driving. Boosting. FUN!
jpnovak
post Sep 22 2009, 10:09 PM
Post #81
They call me "Nanoman"
I wanted to introduce myself as a new member to the World. I am new to the 914 but not new to air-cooled. I have two 1971 911s; a T - soft-window targa and an ST-replica track car. I am sure I have seen many of you on Pelican. With the 911 I have done it all, rust repair, paint, engines, transmissions and chassis setup. I felt it was time for something new.
Introducing my new project. "Dirty Penny"
Penny is a 1975 Porsche 914. She has been sitting unattended for a while. I found her at a friends house under the old oak tree. Penny is wearing copper metallic paint and had a white interior. Penny arrived without a heart. I am going to give her new life.
Penny will be built as a Grassroots Motorsports $2010 Challenge car. For those not familiar that means you have $2010 to build a car where it competes in a concours, drag race and autocross. The prize? Notoriety in GRM and ridicule from those who already think you are nuts and cheap. My wife doesn't affectionately call me Fred Sanford for nothing. (IMG:style_emoticons/default/smile.gif)
Here are a few pictures of Penny being unearthed from her previous home. The TX sun has not been kind to the paint, nor the interior. However, the dry climate has left her remarkably rust free. There is rust in the Hell Hole that has been previously cut out yet never welded back in. Rot is almost non-existent.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889178.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889179.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889179.3.jpg)
How much money I have left to spend on the project.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889180.4.jpg)
The plan is simple to do well at the Challenge. Get a car that handles well. Strip the weight out of it. give it some extra HP. Let's see... A 914 handles well. they are already pretty light. but the Type IV doesn't lend itself to high HP without major $$$.
A bit of late night ebay browsing and I came across a JDM Subaru EJ20G drivetrain. Yes, that's what I need. ITs still a flat-4 - yet has to be water cooled and makes 140+ HP/L in stock trim. I like it. The vendor was in Dallas which means reduced shipping costs. Yep, that's the rule. you must account for ALL purchases.
The new heart and soul... Oh yeah it will have soul!
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889180.5.jpg)
to be honest, work has been crazy and I have 13 months to build the car. Progress won't be fast. I am excited to make this go forward. The challenge of swapping the entire drivetrain begins with connections. The engine mounts are easy. Trying to get the shift linkage, clutch linkage and throttle cable done on the cheap is not so easy. I know there is a wealth of information on this site. Thanks to all those who have traveled this road before me.
Until the next update...
Now I have to figure out how to post images on this site rather than link external.
jpnovak
post Jul 5 2011, 11:47 AM
Post #82
I thought I would bump this thread since I finally moved on to get some progress completed.
The car and project goals are still alive. Just delayed a year or so. Life, family and work got in the way. Now I am committed to getting Penny to the Challenge! Hey, I have an extra dollar to spend this year.
I will update some pictures later tonight but thought I would give a brief description of my progress (and lack of).
1. The cooling system is in. I bought some EPDM heavy wall hose from McMaster Carr. This 1.25" ID/2"OD hose runs under the car through the floor stamping recess that outlines the center tunnel. Like others before me I snake the hose between the front suspension cross member and steering rack. In the rear I machined adapters that step from 1.25" up to 1.5" using scrap aluminum. This mates to the factory Suby inlet/outlet. Looks clean and is leak free.
Interesting note: Red hose is $0.40/ft cheaper than black hose. Guess what color my radiator hose is. Besides, red is faster right?!
2. Shifting system. I used Evinrude boat control cables I found on eBay for $5. These mate to welded adapters on the shift-select rod.
In the car I installed a manual shifter from a Nissan Versa. I know its not the same as most other builds but there are a few notable differences. First the shift cables exit the front and then loop down through the tunnel. Worked perfectly with my long boat cables. SEcond the shift position is fantastic. The shifter knob is located to the right about 6", back about 3" and middle of the wheel for height. My hand naturally drops of the steering wheel and onto the knob. The throw is about 3" front-to-back and about 2" side-to-side.
Oh, I was the one with he DIY Bremar kit. Shifting works great now.
3. Fuel system. I pulled the tank and cleaned it out. Then I made my own rust etch and ended up with a nice, internally clean tank. I used a Ford Crown Vic fuel pump. Also used on the 98 F150 and a bunch of other Ford cars. Fuel pressure spec is up to 50psi and plenty of delivery volume. Best of all it was $30 delivered.
The stock fuel lines were cleaned and connected to the subaru fuel inlet/outlet using a bridge fuel hose. my 75 had the poly lines through the tunnel. The OD is the same as the ID of the stock Subaru hose. A simple clamp made the connection. Simple, cost nothing and is leak free.
4. Wiring and electrical. This is where I have had the most trouble. I bought a JDM 98 Forester turbo drivetrain. Great except that the wiring diagrams are one-year only and really do not exist. Thankfully all of the GC-X (X = 1-8) series EJ20 motors have similar pin-outs even if the wiring colors are vastly different. It litterally took me 2.5 months to trim the factory subaru harness down to the engine controls. I have traced every wire coming out of the ECU and verified the colors were correct. This was difficult considering that 80% were different colors compared to the wiring diagrams I was using. I found that the UK version of the 1998 WRX had the best match for a wiring diagram.
Once I had the ECU wired in the car I started to make connections to the 914 wiring. Where do I start?
ON a car that sat for 12 years it was an exercise in frustration the first time I connected the battery. Nothing worked. First I cleaned the ignition switch. Then the main relay. Then the light switch. Then all of the grounds. Finally, the lights, starter, fuel pump and most of the gauges work.
Someone please answer this question. Why did the factory switch wire colors from Black/Red to green in the middle of the wiring harness under the dash for the fuel pump 12V supply? I spent hours tracking that down and only found it by splitting the harness and pulling out the wire to find the change in color. This change was not noted in ANY 914 wiring diagram I could find.
Yesterday I was very excited to finally reach the point of starting the motor. I bought some oil late yesterday afternoon and filled the sump. Next I primed the fuel system and turned the key. Spins and spins yet, no spark/no injector pulse. HMM. Time to start tracking signals starting with the crank sensor.
Hopefully, I will get this car started soon. Then it is off to more important things like building axles, figuring out the clutch and rebuilding the brake system. First, it must run.
jpnovak   Introducing "Dirty Penny" - Former $2010[$2012] GRM Project   Sep 22 2009, 10:09 PM
Justin Fischer   Hey Jamie, Been a while since I last saw you in D...   Sep 22 2009, 10:14 PM
jpnovak   Hey Justin, It has been a while. For some reason...   Sep 22 2009, 10:19 PM
Travis Neff   This should be a great thread! :popcorn:   Sep 22 2009, 11:09 PM
Todd Enlund   Sweet! That's two 914s for the $2010...   Sep 23 2009, 01:21 AM
jpnovak   I mocked up the engine mount in CAD. The package ...   Oct 27 2009, 07:02 AM
jpnovak   Next I had to start work on the engine yoke. Up u...   Oct 27 2009, 07:03 AM
ConeDodger   Hey! I lived on the same block as a "Dirt...   Oct 27 2009, 10:22 AM
strawman   Kewl, another Suby swap! My swap is chronicled...   Oct 27 2009, 10:35 AM
jpnovak   Rob, I am not sure of your connotation. I truly ...   Oct 27 2009, 01:35 PM
9146986   That is one of my favorite color combinations. Me...   Oct 27 2009, 07:47 PM
grouperalley   great car for $2010. You've read the rule...   Oct 28 2009, 09:22 PM
camaroz1985   Looking good. How's the progress coming? My ...   Feb 2 2010, 02:22 PM
jpnovak   The motor and tranny mounts are done. I am curren...   Feb 2 2010, 03:47 PM
jpnovak   I thought I would bump this thread since I finally...   Jul 5 2011, 11:47 AM
SirAndy   :ttiwwp: :woohoo:   Jul 5 2011, 12:09 PM
camaroz1985   Congrats on getting this far. Life got in the way...   Jul 5 2011, 12:39 PM
jpnovak   yes, life has a way of getting in the way. My wif...   Jul 6 2011, 12:48 PM
jpnovak   Still no start on the ECU. I used the O-scope las...   Jul 7 2011, 09:18 AM
jpnovak   I am GO for MS. The factory ECU is dead. I don...   Jul 8 2011, 07:41 AM
jpnovak   Penny is alive!! Despite the triple digit...   Jul 24 2011, 04:00 PM
clow   Penny is alive!! Despite the triple digi...   Jul 24 2011, 04:45 PM
jpnovak   Currently, I am almost to ~$1900. Of course,...   Jul 24 2011, 08:33 PM
jpnovak   FYI, I just moved a work trip and am now clear fo...   Sep 8 2011, 10:10 PM
SirAndy   :ttiwwp:   Sep 9 2011, 12:47 AM
rick 918-S   :ttiwwp: :agree: :popcorn:   Sep 9 2011, 05:04 AM
jpnovak   22 days left! That's it to complete a lon...   Sep 12 2011, 08:28 AM
jpnovak   Crossing things off the list... 14 days and count...   Sep 20 2011, 07:31 AM
jpnovak   The competition has just been announced. Compare ...   Sep 21 2011, 04:00 PM
rick 918-S   Cool! Be sure to post pics of your competition...   Sep 21 2011, 05:30 PM
jpnovak   9 days and Counting... It appears that this proje...   Sep 25 2011, 06:21 PM
rick 918-S   I'm excited for you. Good luck! Be sure to...   Sep 25 2011, 06:43 PM
jpnovak   Agreed. A nut and bolt effort is on the list. Ev...   Sep 25 2011, 06:58 PM
rick 918-S   If I was in Texas :smash: :sawzall: I would be o...   Sep 25 2011, 07:45 PM
jpnovak   Ahh Texas where at the end of September it was 105...   Sep 26 2011, 07:35 AM
jpnovak   Despite another heat wave and hectic work schedule...   Sep 27 2011, 07:32 AM
Brett W   What did you do about the axles? Did you have the...   Sep 27 2011, 07:33 PM
jpnovak   The Subaru and 914 axles are the same diameter (+/...   Sep 27 2011, 08:18 PM
Brett W   You might paint a white line the length of your ax...   Sep 28 2011, 06:41 AM
jpnovak   Great suggestion. I was going to have them heat...   Sep 28 2011, 07:00 AM
Eric_Shea   :ttiwwp: of the buffed out, decaled car! :D   Sep 28 2011, 08:23 AM
jpnovak   I have been working late for the day job and then ...   Sep 28 2011, 11:30 AM
jpnovak   Manged to get the tail lights installed and workin...   Sep 29 2011, 11:00 AM
jpnovak   All buffed up and somewhere to go... http://www....   Sep 29 2011, 09:54 PM
jpnovak   Tonight felt like there was nothing accomplished. ...   Sep 29 2011, 09:56 PM
jpnovak   Penny is out and about. Trying to sort the car ar...   Oct 1 2011, 01:59 PM
bfrymire   http://www.914world.com/bbs2/uploads_offsite/for...   Oct 1 2011, 05:08 PM
Cupomeat   Penny is out and about. Trying to sort the car a...   Oct 3 2011, 01:40 PM
rick 918-S   Looks good. Neaten up that wiring. No DNF's fo...   Oct 1 2011, 05:23 PM
jpnovak   I am getting ready to put the car on scales and se...   Oct 1 2011, 06:26 PM
shuie   Cool man. Thanks for sharing! Good to see you ...   Oct 1 2011, 09:15 PM
jpnovak   Hey Sherman, How are things in LA? I will passin...   Oct 1 2011, 09:34 PM
jpnovak   I just pulled my car off the scales. Oh so close ...   Oct 1 2011, 09:36 PM
bfrymire   I just pulled my car off the scales. Oh so close...   Oct 1 2011, 11:05 PM
jpnovak   Brett, You are correct. However, there is some a...   Oct 2 2011, 05:48 PM
rick 918-S   Damn! that ECU thing sux! When you get tha...   Oct 2 2011, 06:10 PM
jpnovak   I think I have found the solution to the ECU probl...   Oct 2 2011, 06:43 PM
jpnovak   ECU problems fixed for now. I came home at lunch ...   Oct 3 2011, 12:09 PM
bfrymire   ECU problems fixed for now. I came home at lunch...   Oct 3 2011, 01:21 PM
jpnovak   Brett, the key is a 12K resistor in series with t...   Oct 3 2011, 04:08 PM
Dave_Darling   For (very) slightly more support, remove the lower...   Oct 3 2011, 04:53 PM
jpnovak   Great suggestion. I had already started to take t...   Oct 4 2011, 07:45 AM
jpnovak   last night I was trying to get the car ready for t...   Oct 5 2011, 07:54 AM
mojorisen914   May the force be with you.   Oct 5 2011, 11:41 AM
jpnovak   Managed to get almost 8 hours on the road before i...   Oct 5 2011, 09:25 PM
jpnovak   Made it Gainesville. Almost 1100 mile tow. A few...   Oct 6 2011, 07:46 PM
rick 918-S   Do us proud man! Lots of photos! Is that y...   Oct 6 2011, 09:25 PM
jpnovak   Disappointment. What can I say but... Disappoi...   Oct 7 2011, 03:34 PM
bfrymire   Wow. sorry to hear... Did you pull the pan? See...   Oct 7 2011, 06:34 PM
Eric_Shea   Fixed your link. Sorry :(   Oct 7 2011, 04:28 PM
Cairo94507   Sorry to hear that.   Oct 7 2011, 04:59 PM
dlee6204   Wow this sucks... :( Sorry.   Oct 7 2011, 05:42 PM
rick 918-S   Wow That blows! :( Can you fix the engine and...   Oct 7 2011, 06:11 PM
trojanhorsepower   Bummer. You will show'em next year.   Oct 7 2011, 06:25 PM
strawman   Arrrgh, that sux! I have an EJ20 shortblock ...   Oct 7 2011, 06:42 PM
jpnovak   Thanks for the condolences. I had 1100 miles to r...   Oct 9 2011, 07:46 PM
kg6dxn   You should call Strawman!   Oct 9 2011, 08:08 PM
RonW   jamie, just followed your link to this thread afte...   Oct 11 2011, 11:49 PM
jpnovak   Update... I started investigating the engine fa...   Oct 13 2011, 12:07 PM
SLITS   Make a list of the parts you will need and post it...   Oct 13 2011, 05:21 PM
strawman   Jamie, I finally got time to strip the Subaru EJ20...   Oct 15 2011, 07:58 PM
jpnovak   I am opening this thread up again. I have a new...   Jul 11 2012, 08:25 AM
smj   Woo hoo! Heartbreaking to read about what happ...   Jul 11 2012, 06:57 PM
jpnovak   So the usual parts of life have gotten in the way....   Jan 8 2013, 10:45 PM
rnellums   Did you ever find what failed?   Jan 9 2013, 12:45 PM
FourBlades   Good luck with the car! :Qarl: Grassroots m...   Jan 9 2013, 08:47 PM
jersey914   Yeah, what ever happened to cause the engine failu...   Jan 9 2013, 09:34 PM
jpnovak   The engine failure was two fold. 1. The oil pa...   Jan 10 2013, 04:35 PM
jpnovak   This weekend I made a bit of progress. Both intak...   Jan 14 2013, 07:43 AM
jpnovak   Lots of progress today. intake is on and sealed....   Jan 19 2013, 05:55 PM
jpnovak   Well, the drivetrain is back in the car. clutch a...   Jan 20 2013, 08:33 PM
jersey914   I can't imagine you'd could have the oil i...   Jan 20 2013, 08:46 PM
jpnovak   Let's hope not. My wife will probably want th...   Jan 21 2013, 12:59 PM
DBCooper   Sorry I'm late with this, but I just saw this ...   Jan 22 2013, 07:57 AM
jpnovak   I only used the oil pickup. I did not buy the pan...   Jan 22 2013, 10:16 AM
jpnovak   Ready, Steady, GO! So, Last night I discovere...   Jan 22 2013, 10:37 PM
jersey914   Can't wait to see Penny's 2012 version of ...   Jan 23 2013, 09:31 PM
jpnovak   Penny is alive. Started her up this morning after...   Jan 26 2013, 08:06 AM
Justin Fischer   Congrats Jamie!!! Your projects are al...   Jan 26 2013, 08:09 PM
jpnovak   Well, She is not driving around the block yet but...   Jan 27 2013, 07:50 PM
- Lo-Fi Version Time is now: 16th June 2024 - 08:51 PM
