My motor is headed back to Series9, Its going to kick its smoking habit |
MoveQik |
Jun 23 2011, 05:07 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I have this on Narp but I know most of you don't check in there too often. I thought I would put it here as well so all can see what Joe is up to.
Buying a used motor is always a roll of the dice. Mine has ran strong since Joe put it in but the smoking issue(valve guides seem to be the most common diagnosis) has become worse over time and the oil leaks are no longer small. (IMG:style_emoticons/default/mad.gif) So we struck a deal that has me pulling the motor and sending it to Joe to rebuild. Then he is coming out to help me put it back in(read as, he is letting me slow him down). There are added costs in doing this obviously but Joe made it more than fair and it worked out to be cheaper than having any of our local shops do the work and hand me back a freshened up motor. Plus, I get some more much needed hands on experience. I got the motor out yesterday. I will be pulling off parts that I want to pretty up while Joe has the motor. I am also going to take this time to clean up and respray the engine bay. The before photo, fresh out of the car: Attached thumbnail(s) |
r_towle |
Jul 7 2011, 03:02 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Joe, first off, its great to see what you are working on....lots of fun to watch.
Given you are trying to get things done, your pictures are really appreciated. On that note, would you please post pics of any "special" tools that you might need as you use them. The valve timing stand is one.. The rocker arms need a special tool, or special setup to get them loose/tight? Anything else that comes to mind would be great. Rich |
Series9 |
Jul 7 2011, 04:59 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Joe, first off, its great to see what you are working on....lots of fun to watch. Given you are trying to get things done, your pictures are really appreciated. On that note, would you please post pics of any "special" tools that you might need as you use them. The valve timing stand is one.. The rocker arms need a special tool, or special setup to get them loose/tight? Anything else that comes to mind would be great. Rich The 'Z block' for the dial indicator is very common in Porsche circles and is available on eBay every day. http://cgi.ebay.com/ebaymotors/Valve-Tool-...#ht_5400wt_1167 Your ability to use it is an acquired skill. The rockers only require Allen keys and a long drift for removal. Obviously, you need to unload the rocker before you can drive the rocker shaft out of its bore. By 'unload', I mean turn the cam until the valve is completely closed and there is no load on the rocker arm. Removing the nut on the sprocket-end of the cam(or bolt, depending upon the year of the engine) requires a few special tools. If your engine was built before 1981, you need these two: http://cgi.ebay.com/ebaymotors/Cam-Camshaf...omotiveQ5fTools If your engine was built after 1981, you need: http://cgi.ebay.com/ebaymotors/911-Porsche...s#ht_683wt_1167 |
Lo-Fi Version | Time is now: 4th June 2024 - 06:41 AM |
