FS:1973 1.7L 914 $1800.00 Price Reduced Greenwood , IN |
rettigdw914 |
Jul 9 2011, 03:57 PM
Newbie Group: Members Posts: 16 Joined: 17-September 04 From: Greenwood, IN Member No.: 2,774 |
Guys, I am letting my car go, wife wants it out of the house and no more funding is available. Here is the post:
Up for sale is a 1973 Porsche 914 with a 1.7L engine. This car still has fuel injection and has not been replaced with carbs. The following is a list of items replaced/fixed: -All Push Rod tube seals replaced - Valves adjusted -Points have been changed over to compufire electronic ignition -New spark plugs and wires added 6 months ago - Compression test on all 4 cylinders about a year and a half ago was 120 psi with no more than 4 psi variability between cylinders. -Rebuilt fuel pump(30psi solid), -Injectors ultrasonically cleaned -Rebuilt MPS from Bret Instruments -TPS calibrated -Vacuum lines replaced, -Injector seals replaced -Intake runner gaskets and hose to plenum replaced -Rebuilt distributor -New cap,rotor,coil Purchase also includes lots of extra parts, used set on Koni rear struts, a good parts transmisstion, the full factory service manual electronically searchable(over 1000 pages), and much more information on these cars. Items needing to be fixed/improved: - It has low power under load and my mechanic said he is 70% sure it needs a new clutch as it appears to be slipping. Clutch kits are $350.00 - Second gear syncro is worn but it does shift - needs new door handles - crack in windshield - need new engine cover brackets and may need new trunk lid. - some rust on the passenger quarter panel and on the longtitutinals. If you check out the price for a fully restored car, they can go for much more. I simply don't have the time anymore and the wife wants it gone. These are fun cars to drive and they have amazing cornering. Price is $1800.00, cash only and I cannot deliver. I have title on hand. No scams please Due to the clutch issue, it is driveable for about 10 miles, longer than that, I would recommend a trailer, unless you know how to drive a car with a slipping clutch as I do not. Attached thumbnail(s) Attached image(s) |
rnellums |
Jul 11 2011, 08:59 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I also would be interested in some Pictures of the rusty areas. I am located in Lafayette as well.
Lo-Fi Version | Time is now: 6th June 2024 - 03:16 PM |
