It started and ran, no mo knock and a test drive |
76-914 |
Jul 11 2011, 08:57 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I finally got around to starting up the engine last nite. It's a GC case, 2.0 with Rabys FI cam and 911 rocker set up. The P&C's were OK according to Rimco so they just honed the cylinders. I put in a new set of Grant (USA) rings. The heads were rebuilt. New OEM std/std mains (a $200 screwing from our much beloved "King" himself, [I ain't missing him so far]), a rebuilt MPS (thx Geoff/ aka Bleyseng) and a new set of injectors. I used the set of points and condensor that came with the car because I will change out to Petronix once the bugs are out. The plug wires are OK but will be changed out, also.
I was surprised that it caught and fired so quickly (IMG:style_emoticons/default/biggrin.gif) but wasn't so happy with the knocking sound. (IMG:style_emoticons/default/sad.gif) It didn't sound like a rod knocking, though). It also was running on 3 cylinders. I shut it down and pulled the plugs. #2 plug wire was not seating so that was a no brainer. The others looked ok. There were no oil leaks, yet. Oil pressure upon start up was 45psi and FP was 27-29psi. When restarted it was much smoother but still knocking. I crawled beneath but couldn't hear it. I crawled in the cabin and noticed that the noise changed and quited as I pushed on the shifter (IMG:style_emoticons/default/confused24.gif) . I'll pull the tranny later this week, start it and see if it is quite. Foolish confidence told me that it wasn't a rod knocking so I completed the break in run on the cam. The noise has almost gone away since the break in run. (IMG:style_emoticons/default/dry.gif) I noticed that the air cleaned had held the cooling flaps in the cold or closed position for the first 10 min's of run time which I think contributed to the drop in oil pressure. It had dropped to 20 psi by now. BTW, it is the std T4 oil pump. More to come later. Comments and input/opinions greatly appreciated. |
stugray |
Jul 12 2011, 01:03 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
"Quit sniffing the tailpipe ...."
Actually that is one of my favorite ways to do a quick check on any VW engine. A trained nose can tell quickly if it is too rich or lean ;-) Also, 76-914 I hope you are not running the engine for very long with the battery charger still hooked up and plugged in. That is a good way to kill your voltage regulator. Stu |
Lo-Fi Version | Time is now: 9th June 2024 - 11:43 PM |
