> What do I do about rear springs?, My ass is way up in the air!
Zeke
post Apr 12 2003, 04:49 PM
Never left, but not right....
I have Koni streets on the rear with the non adjustable perch for ride height. I want to lower the car. At this point, if I want to keep Konis, I have to buy yellow "sports" and smaller diameter (2 1/2 ID) springs and threaded collars to accomplish what I need.
After 15 months of construction, I am out of money, but the car is finished save for the rear springs. I just want to track it a couple of times before choosing new suspension stuff. I can't find any short stiff springs to lower the car with the Konis. So, I am thinking of cutting down some 160# stock height springs that came with the street Konis off a six conversion that wrecked.
If I cut the springs and bend the wind at the base to fit in the perch better, I will have about a 185-190 short spring. That fits pretty well with my front 22mm T-bars. I could use some advice before I do this.
tryan
post Apr 13 2003, 01:23 PM
if you overload a spring. ( ie compress it beyond yield strength ) you might be able to make it shorter. sounds dangerous, but possible.
heat from cutting or cold working will make the ductile spring steel more brittle. you might pack some ice on the spring while you cut or bend. not liquid nitrogen, but cool.
is there anyway to modify/lower the existing perch? can you canabilize the street koni's off the 6?
you might have the first sport ute porsche. (IMG:style_emoticons/default/rolleyes.gif) naw, somebody already did that.
Zeke   What do I do about rear springs?   Apr 12 2003, 04:49 PM
Jeroen   I may be wrong, but as far as I know, the springra...   Apr 12 2003, 05:10 PM
TimT
  Apr 12 2003, 05:34 PM
Racer Chris   Shortening the springs will stiffen them because a...   Apr 12 2003, 05:41 PM
Jeroen   Hey Milt, Well, these guys have proven me wrong (...   Apr 12 2003, 05:52 PM
Zeke   Jeroen, I wouldn't give it a second thought. Y...   Apr 13 2003, 09:52 AM
street legal go-kart   zeke having spent a lot of time playing with round...   Apr 13 2003, 10:28 AM
Zeke   Very much appreciated! I'm sure that's...   Apr 13 2003, 10:55 AM
Mueller   I think an angle grinder would be much easier to u...   Apr 13 2003, 11:04 AM
Bleyseng   Even if you used a Hackmaster metal cutting blade ...   Apr 13 2003, 11:57 AM
tryan   if you overload a spring. ( ie compress it beyond ...   Apr 13 2003, 01:23 PM
Zeke   The only way to modify (I don't want to canaba...   Apr 13 2003, 06:30 PM
Sammy   Cut away. But I would get a real old set of stocke...   Apr 13 2003, 07:45 PM
TimMartin     Apr 13 2003, 08:05 PM
street legal go-kart   hey zeke any modern welding shop will have a plasm...   Apr 13 2003, 08:05 PM
street legal go-kart   ps i totaly agree with the post by tim martin , i...   Apr 13 2003, 08:08 PM
Racer Chris   Just have a wet rag handy to cool the hot area aft...   Apr 14 2003, 06:37 AM
Zeke
- Lo-Fi Version Time is now: 13th July 2025 - 04:36 PM
