FS, Big Type IV engine components to build a 2613cc, 103mm Nickies, JE pistons, Crank, Rods, Bearings, etc.... |
MLedesma |
Sep 21 2010, 10:26 AM
Member Group: Members Posts: 52 Joined: 13-October 06 From: Elizabeth, CO Member No.: 7,036 Region Association: Rocky Mountains |
Well after sitting on these parts for 2 years now, I have come to the realization that I am not ready to use them and build my big type IV. It just doesn’t make sense as my project still needs body work, paint, interior and other miscellaneous items before it could use an upgraded motor. I could also use the funds from the sale to pay for the above. I will come back to a big IV or a Raby kit at another time.
These parts came with the purchase of a second project car. So some of the information I have about them is incomplete. Also looking at the dates on some of the parts the previous owner sat on these parts for some time as well before selling them to me. What I have here is nearly everything you need to build a 2613 cc longblock engine (does not include induction or exhaust). The components that you will need to source are; Camshaft and Lifters (sold earlier as I didn’t want a Hydro cam and lifters) Cam Gear Seals, Seal Kit Oil galley plugs Piston Rings (somehow lost between the previous owner and me) Flywheel Also missing the distributor drive gear and the cam drive gear on the crankshaf The following is all new and/or rebuilt parts LN Engineering 103mm Nickies Includes required ARP head studs and hardware JE Pistons (four are marked 425, and one is marked 426) DPR 78.4mm Crank 2.0” Journal, welded, counterweighted. Scat H beam rods (5.325 length with 22mm wrist pin, big end weight 400, small end 189) Kolbenshmidt Bearings (I am unsure of the exact size) Mahle cam bearings Clevite rod bearings Schadek 30mm HD oil pump ARP Case Through bolts and hardware Push rods and ends (chromoly) New push rod tubes Billet roller rockers Rebuilt 1.7 heads, port and polish intake and exhaust, 42 X 36 stainless steel valves, HD single springs (that is what the receipt says but they look like dual springs to me) and new retainers, new guides, and seats (course I cannot see them). Stamped at 79cc (might want to double check this, as I had planned to. Work done by Mark Stephens High Performance in 1998. Case machined for 103 mm cylinders, oil galleys drilled and tapped (missing plugs). This is a GD stamped case, which I believe is a 2.0 out of a 76-78 transporter This case has the dipstick in a different location than a stock 914 (which will need to be modified if used in a 914). I will also include all the engine tin, oil cooler, fan and fan shroud (fan is missing a couple fins), hardware and any other parts as they were given to me. I can get pictures if necessary. I believe these to be quality parts to the best of my knowledge, no warranty of parts is expressed or implied. This is not a complete kit and you will need to source some parts to complete an engine build. The majority of these parts were purchased by the previous owner through LN engineering as some of the paperwork I have includes emails between them. Also some of the parts were shipped to LN engineering and then to the PO. I am sure I have forgotten somethings. I can easily get more detailed picstures as needed. I used a lower resolution on the camera and shrunk them so I could post them here. Please contact me via PM should you be interested or have any more questions. If you would like to speak with me please include a phone number and a good time to reach you. I am pricing this package at $5000.00 USD. Shipping will be additional but can be negotiated (I have a very good FedEx discount through my work). Matt Nickies JE pistons |
MLedesma |
Jul 18 2011, 10:44 PM
Sorry, all parts have been sold and shipped.
Lo-Fi Version | Time is now: 4th June 2024 - 09:06 PM |
