| DRPHIL914 |
Jul 19 2011, 10:26 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,874 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States
I have a 75 2.0, with 8spoke empi 15" 4 lug, and 195/55 performance tires. Currently have bilistein sport shocks, adjustable with newer #100 springs. When set higher to give better clearance its pretty bouncy, so I moved them down 3 notches to take tension off springs but before I rolled the fender lips they would have almost zero clearance on outside.
Would going to #140s help. I know there is an inch diff in height so if I put the shock setting higher- more pressure on the spring I will get a little higher ride, but will it be too stiff for daily driving and the occasional d.e. on the road course- robeling road? It should bounce less but . Anyone used this combination? I've not had the #140s but have a chance to buy some. Need some I.put to make a decision on this. Thanks Phil I also have stock sway bar with new bushings |
| Dr Evil |
Jul 19 2011, 10:45 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
140 (IMG:style_emoticons/default/wink.gif)
Philip W. weltmeister springs - which do you suggest. Jul 19 2011, 10:26 PM
Philip W.
140 ;)
O.k so my stupid phone posted this twice... Jul 19 2011, 10:54 PM
kg6dxn That's not funny! :( Jul 19 2011, 10:47 PM
SUNAB914 I believe 140's will make it lower. Jul 20 2011, 06:55 AM
sean_v8_914 springs and dampers should be better matched. whil... Jul 20 2011, 07:16 AM
Philip W.
springs and dampers should be better matched. whi... Jul 20 2011, 07:38 AM
pcar916 I'd go for the 140's in a heartbeat.
They... Jul 20 2011, 07:59 AM
Cupomeat Hey, I thought that Bilstein shocks are not adjust... Jul 20 2011, 08:26 AM
Philip W. I have sway bar with new bushings,
the shocks are... Jul 20 2011, 10:09 AM
Cupomeat
the shocks ar... Jul 20 2011, 05:03 PM
Vacca Rabite I have weltmiester 140s on my car with nonadjustab... Jul 20 2011, 08:45 AM
Vacca Rabite Also, with 140s you can use stock front A arms bu... Jul 20 2011, 08:48 AM
eric9144 I have 140# springs on red Koni adjustables, stock... Jul 20 2011, 11:15 AM
eric9144 Edit: duplicate post :) Jul 20 2011, 11:16 AM
Philip W.
I have 140# springs on red Koni adjustables, stoc... Jul 20 2011, 12:32 PM
draganc
I have 140# springs on red Koni adjustables, sto... Nov 16 2011, 08:42 PM
Philip W.
[quote name='Philip W.' post='1512059' date='Jul ... Nov 17 2011, 09:02 AM
eric9144 With my perches set to the lowest position my ride... Jul 20 2011, 02:17 PM
stugray HELP! I am about to buy the Ground Control coi... Nov 16 2011, 01:51 PM
DanT
HELP! I am about to buy the Ground Control co... Nov 16 2011, 03:47 PM
yeahmag I disagree. I have 21mm torsion bars and have gone... Nov 16 2011, 03:56 PM
DanT IIRC hollow 23mm bars are the equivalent spring ra... Nov 16 2011, 04:45 PM
yeahmag Were you running Hoosiers? Things changed quickly ... Nov 16 2011, 05:03 PM
DanT
Were you running Hoosiers? Things changed quickly... Nov 16 2011, 05:05 PM
stugray "Are you running a rear bar? LSD? Shocks? Sto... Nov 16 2011, 05:46 PM
yeahmag The stock rubber adds perceived spring rate as it ... Nov 16 2011, 05:48 PM
majkos :agree: doesn't look correct. Nov 17 2011, 09:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 06:29 PM |
