I have sway bar with new bushings,
the shocks are adjustable in the location of the retention ring location for the spring, so you have a higher ride with morepressure sooner on the spring, or if it is lowered, then more demand on the shock,less on the spring and lower ride.
I have not gotten to the front. The back was bad old koni and weak springs.
The front is the next project. It feels good, but will atleast need the sway bar as zach said.
What are snubbers?
QUOTE(Cupomeat @ Jul 20 2011, 10:26 AM)
Hey, I thought that Bilstein shocks are not adjustable in dampening/rebound?
Do you mean that you adjusted the spring perch? Raising and lowering the spring perch will have no impact on ride.
I did the googles on the intranets
and can't find any Bilstein Sport shocks that are adjustable... Please clarify, as a complete answer to your question relies on this attribute.
SO, either way, here is my opinion.
If you have Bilstein sports on the back and no anti-roll bar, use the 140# springs (as they are a better match for the Sport shocks) and use the Koni sport snubbers.
If you have an anti roll bar in the back, go with the 140# springs, but stick to the stock snubbers.
The Koni sport snubbers will allow the rear shocks to compress an amount before significantly increasing the combined spring rate. This would be best for a car with no anti-roll bar as the anti-roll bar increases the combined spring rate in a corner as well.
Now, what are you running in the front end? I would think you need to match your suspension. You could get by with 19mm torsion springs if you have Bilstein sprot struts upfront. As the front of the car is lighter, the front of the car will have a bigger impact on the actual ride of the car.
I hope this helps.
