> weltmeister springs - which do you suggest., how much difference is there between #100 & #140's?
DRPHIL914
post Jul 19 2011, 10:26 PM
Dr. Phil
I have a 75 2.0, with 8spoke empi 15" 4 lug, and 195/55 performance tires. Currently have bilistein sport shocks, adjustable with newer #100 springs. When set higher to give better clearance its pretty bouncy, so I moved them down 3 notches to take tension off springs but before I rolled the fender lips they would have almost zero clearance on outside.
Would going to #140s help. I know there is an inch diff in height so if I put the shock setting higher- more pressure on the spring I will get a little higher ride, but will it be too stiff for daily driving and the occasional d.e. on the road course- robeling road? It should bounce less but .
Anyone used this combination? I've not had the #140s but have a chance to buy some.
Need some I.put to make a decision on this.
Thanks
Phil
I also have stock sway bar with new bushings
sean_v8_914
post Jul 20 2011, 07:16 AM
Chingon 601
springs and dampers should be better matched. while the bilstein sport is a great shock, it is a bit firm for stock springs. it will feel better with 140 springs.
DRPHIL914
post Jul 20 2011, 07:38 AM
Dr. Phil
QUOTE(sean_v8_914 @ Jul 20 2011, 09:16 AM) *
chris, Sean-
thanks for the input, - yes the 140# when on according to welt. sit 1" lower.
so i would probably adjust the shocks up a couple notches, and was hoping that the 140# stiffness would work better with those shocks and reduce the bounce, and still give a decent ride yet work well for the A.X and D.E. - setting it high puts more stress on the springs, whereas lower takes it off the springs, putting more demand on the shock, also reducing thebounce,, i'm just wondering what the best balance, and set up would be.
one other factor is the tires, obviously the lower profile wider 195/55 will feel different than a 165/70 as well. -
thanks for the input.
phil
Philip W.   weltmeister springs - which do you suggest.   Jul 19 2011, 10:26 PM
Dr Evil   140 ;)   Jul 19 2011, 10:45 PM
Philip W.   140 ;) O.k so my stupid phone posted this twice...   Jul 19 2011, 10:54 PM
kg6dxn   That's not funny! :(   Jul 19 2011, 10:47 PM
SUNAB914   I believe 140's will make it lower.   Jul 20 2011, 06:55 AM
sean_v8_914   springs and dampers should be better matched. whil...   Jul 20 2011, 07:16 AM
Philip W.   springs and dampers should be better matched. whi...   Jul 20 2011, 07:38 AM
pcar916   I'd go for the 140's in a heartbeat. They...   Jul 20 2011, 07:59 AM
Cupomeat   Hey, I thought that Bilstein shocks are not adjust...   Jul 20 2011, 08:26 AM
Philip W.   I have sway bar with new bushings, the shocks are...   Jul 20 2011, 10:09 AM
Cupomeat   I have sway bar with new bushings, the shocks ar...   Jul 20 2011, 05:03 PM
Vacca Rabite   I have weltmiester 140s on my car with nonadjustab...   Jul 20 2011, 08:45 AM
Vacca Rabite   Also, with 140s you can use stock front A arms bu...   Jul 20 2011, 08:48 AM
eric9144   I have 140# springs on red Koni adjustables, stock...   Jul 20 2011, 11:15 AM
eric9144   Edit: duplicate post :)   Jul 20 2011, 11:16 AM
Philip W.   I have 140# springs on red Koni adjustables, stoc...   Jul 20 2011, 12:32 PM
draganc   I have 140# springs on red Koni adjustables, sto...   Nov 16 2011, 08:42 PM
Philip W.   [quote name='Philip W.' post='1512059' date='Jul ...   Nov 17 2011, 09:02 AM
eric9144   With my perches set to the lowest position my ride...   Jul 20 2011, 02:17 PM
stugray   HELP! I am about to buy the Ground Control coi...   Nov 16 2011, 01:51 PM
DanT   HELP! I am about to buy the Ground Control co...   Nov 16 2011, 03:47 PM
yeahmag   I disagree. I have 21mm torsion bars and have gone...   Nov 16 2011, 03:56 PM
DanT   IIRC hollow 23mm bars are the equivalent spring ra...   Nov 16 2011, 04:45 PM
yeahmag   Were you running Hoosiers? Things changed quickly ...   Nov 16 2011, 05:03 PM
DanT   Were you running Hoosiers? Things changed quickly...   Nov 16 2011, 05:05 PM
stugray   "Are you running a rear bar? LSD? Shocks? Sto...   Nov 16 2011, 05:46 PM
yeahmag   The stock rubber adds perceived spring rate as it ...   Nov 16 2011, 05:48 PM
majkos   :agree: doesn't look correct.   Nov 17 2011, 09:00 AM
- Lo-Fi Version Time is now: 8th December 2025 - 06:29 PM
