| DRPHIL914 |
Jul 19 2011, 10:26 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,874 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States
I have a 75 2.0, with 8spoke empi 15" 4 lug, and 195/55 performance tires. Currently have bilistein sport shocks, adjustable with newer #100 springs. When set higher to give better clearance its pretty bouncy, so I moved them down 3 notches to take tension off springs but before I rolled the fender lips they would have almost zero clearance on outside.
Would going to #140s help. I know there is an inch diff in height so if I put the shock setting higher- more pressure on the spring I will get a little higher ride, but will it be too stiff for daily driving and the occasional d.e. on the road course- robeling road? It should bounce less but . Anyone used this combination? I've not had the #140s but have a chance to buy some. Need some I.put to make a decision on this. Thanks Phil I also have stock sway bar with new bushings |
| Cupomeat |
Jul 20 2011, 08:26 AM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Hey, I thought that Bilstein shocks are not adjustable in dampening/rebound?
Do you mean that you adjusted the spring perch? Raising and lowering the spring perch will have no impact on ride. I did the googles on the intranets (IMG:style_emoticons/default/laugh.gif) and can't find any Bilstein Sport shocks that are adjustable... Please clarify, as a complete answer to your question relies on this attribute. SO, either way, here is my opinion. If you have Bilstein sports on the back and no anti-roll bar, use the 140# springs (as they are a better match for the Sport shocks) and use the Koni sport snubbers. If you have an anti roll bar in the back, go with the 140# springs, but stick to the stock snubbers. The Koni sport snubbers will allow the rear shocks to compress an amount before significantly increasing the combined spring rate. This would be best for a car with no anti-roll bar as the anti-roll bar increases the combined spring rate in a corner as well. Now, what are you running in the front end? I would think you need to match your suspension. You could get by with 19mm torsion springs if you have Bilstein sprot struts upfront. As the front of the car is lighter, the front of the car will have a bigger impact on the actual ride of the car. I hope this helps. |
Philip W. weltmeister springs - which do you suggest. Jul 19 2011, 10:26 PM
Dr Evil 140 ;) Jul 19 2011, 10:45 PM
Philip W.
140 ;)
O.k so my stupid phone posted this twice... Jul 19 2011, 10:54 PM
kg6dxn That's not funny! :( Jul 19 2011, 10:47 PM
SUNAB914 I believe 140's will make it lower. Jul 20 2011, 06:55 AM
sean_v8_914 springs and dampers should be better matched. whil... Jul 20 2011, 07:16 AM
Philip W.
springs and dampers should be better matched. whi... Jul 20 2011, 07:38 AM
pcar916 I'd go for the 140's in a heartbeat.
They... Jul 20 2011, 07:59 AM
Philip W. I have sway bar with new bushings,
the shocks are... Jul 20 2011, 10:09 AM
Cupomeat
the shocks ar... Jul 20 2011, 05:03 PM
Vacca Rabite I have weltmiester 140s on my car with nonadjustab... Jul 20 2011, 08:45 AM
Vacca Rabite Also, with 140s you can use stock front A arms bu... Jul 20 2011, 08:48 AM
eric9144 I have 140# springs on red Koni adjustables, stock... Jul 20 2011, 11:15 AM
eric9144 Edit: duplicate post :) Jul 20 2011, 11:16 AM
Philip W.
I have 140# springs on red Koni adjustables, stoc... Jul 20 2011, 12:32 PM
draganc
I have 140# springs on red Koni adjustables, sto... Nov 16 2011, 08:42 PM
Philip W.
[quote name='Philip W.' post='1512059' date='Jul ... Nov 17 2011, 09:02 AM
eric9144 With my perches set to the lowest position my ride... Jul 20 2011, 02:17 PM
stugray HELP! I am about to buy the Ground Control coi... Nov 16 2011, 01:51 PM
DanT
HELP! I am about to buy the Ground Control co... Nov 16 2011, 03:47 PM
yeahmag I disagree. I have 21mm torsion bars and have gone... Nov 16 2011, 03:56 PM
DanT IIRC hollow 23mm bars are the equivalent spring ra... Nov 16 2011, 04:45 PM
yeahmag Were you running Hoosiers? Things changed quickly ... Nov 16 2011, 05:03 PM
DanT
Were you running Hoosiers? Things changed quickly... Nov 16 2011, 05:05 PM
stugray "Are you running a rear bar? LSD? Shocks? Sto... Nov 16 2011, 05:46 PM
yeahmag The stock rubber adds perceived spring rate as it ... Nov 16 2011, 05:48 PM
majkos :agree: doesn't look correct. Nov 17 2011, 09:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 06:29 PM |
