Front end changeover in progress..., 8/8- Alignment woes |
jk76.914 |
Sep 9 2010, 07:45 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I'm finally getting rid of the 4-to-5 lug adapters and doing a real Porsche 5 lug front suspension. Contrary to normal practice, which is normal for me, I guess, I'm installing real 914/6 struts with new Bilstein inserts. I bought the parts about 5 years ago on eBay, and the kit was all-inclusive, with freshly painted struts and new ball joints, bearings, rotors, pads, and brake hardware, and rebuilt M calipers. My excuse is I didn't know any better at the time, or I'd have looked for a later 911 set with the later bearing type, but alas, I own it now and everything is in real nice shape.
I think I'm good to go on parts and tools, but I'm trying to find out the torque requirement for the lock bolt for the ball joint. It's an M10 x 30mm x 1.5mm pitch, going into steel threads in the strut; presumably the lower part of the strut, below the tube, is forged. Looks like an M10 grade 12.9 bolt is good for 50 ft-lbs, but I don't want to chance stripping out the threads. Nor do I want the BJ to pop because it's too loose. Does anyone know the torque spec? Thanks! Picture below- PS- any tips for installing this type of strut? Thanks! |
jk76.914 |
Jul 21 2011, 05:05 AM
ArtechnikA- Thanks for the comments, that may be it or part of it...
I thought of another clue. When my wife pushed on the pedal, there wasn't much flow. On some pushes, there may have been none, or at least so little as to be undetectable. There're weren't bubbles on these pushes either. The most effective combination was 5-7 psi at the MS while she pressed the pedal.... Could the front pistion in the MS be stuck forward? |
Lo-Fi Version | Time is now: 11th June 2024 - 10:23 PM |
