Jack Post Repair Question |
saigon71 |
May 6 2011, 03:33 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I welded a new jack tube on to the replacement wheelhouse section from Restoration Design today, aligning it perfectly with the square hole that came pre-punched in the new panel. When I started fitting the jack post brace, I had to adjust the bends on it by about 1/8" to get it to fit right. I am having a hard time getting accurate measurements from the old chunk of long I have because it is a disaster.
The question is, how reliable is the pre-punched guide hole? Should I just roll with it? Anyone else run into something similar? Thanks in advance. Pics: |
TargaToy |
May 9 2011, 04:32 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Here's what the two pieces from RD look like.
retro74 |
Jul 21 2011, 07:54 PM
Unregistered |
Here's what the two pieces from RD look like. The bottom piece (the inner piece) is no longer listed on Restoration Design. AutomobileAtlanta has the inner piece. If you are just buying the outer piece, you need to fab some inner 16 gauge layers. This part of the car is indeed two layers and those two layers stop where the jackpost meets the longitudinal (horizantal) part. Joe |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:12 AM |
