brake fluid flush, procedures? |
TheCabinetmaker |
Apr 20 2004, 03:07 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm going to my novice DE at Hallett raceway in two weeks, and need to replace my dot 3 with dot 4. I did a search but nothing came up. Everything else on the car is up to specs. Whats the best method to do this? Is it just bleeding the brakes till all the fluid is changed? Do I drain the entire system, then refill and bleed, bleed, bleed?
Thanks in advance, Curt |
tat2dphreak |
Apr 20 2004, 03:48 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I used my little vacuum bleeder... sucked out the resevoir, and then sucked out the lines.... add new fluid and bleed...
maybe that was the wrong way... but it worked |
Lo-Fi Version | Time is now: 11th June 2024 - 11:26 AM |
