brake fluid flush, procedures? |
TheCabinetmaker |
Apr 20 2004, 03:07 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm going to my novice DE at Hallett raceway in two weeks, and need to replace my dot 3 with dot 4. I did a search but nothing came up. Everything else on the car is up to specs. Whats the best method to do this? Is it just bleeding the brakes till all the fluid is changed? Do I drain the entire system, then refill and bleed, bleed, bleed?
Thanks in advance, Curt |
Gint |
Apr 20 2004, 05:50 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Anthony, sounds like air in the prop valve. That's why everybody hates 'em. Crack the lines on the valve and bleed. You can also tap on it while bleeding to help move the air bubbles to the top.
Lo-Fi Version | Time is now: 2nd June 2024 - 10:15 AM |
