> Made some body parts, Need some advice
TargaToy
post Jul 23 2011, 10:07 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
Had to create the transition from the driver's door threshold to the striker plate as well as the leading edge of the front fender. I didn't realize that latter portion was nothing but braze and bondo until I started grinding the paint back to get my cut lines.
The lower section of the rear fender (directly under the sail) is still free from the car. I screwed and clamped it in place while I made the pieces pictured. Once it's welded back onto the car, I am going to have very limited access to the back side of the repairs.
What I WANT to do is treat/seal the back side of the repair which will be the most prone to be hit with moisture/debris from the tire.
That said, here's my issue:
I do not yet own a paint gun, nor epoxy primer. I'm going to Ospho the back side of this area and then I hoped to prime, seam seal, and undercoat it (do not care about not having body color back there--just want "tough") with the fender still unattached to the car.
I know it's frowned upon but is there something in a rattle or brushable product I could treat the area with to make it impervious to the elememts later?
Andyrew
post Jul 23 2011, 02:24 PM
Spooling.... Please wait
Rubberized undercoating will stick to anything.... Just about...
If your worried, spray some aerosol primer down prior to the undercoating.
Just treat that metal or else the rust will come back.
- Lo-Fi Version Time is now: 2nd April 2026 - 05:26 PM
