| TargaToy |
Jul 23 2011, 10:07 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 714 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region
Had to create the transition from the driver's door threshold to the striker plate as well as the leading edge of the front fender. I didn't realize that latter portion was nothing but braze and bondo until I started grinding the paint back to get my cut lines.
The lower section of the rear fender (directly under the sail) is still free from the car. I screwed and clamped it in place while I made the pieces pictured. Once it's welded back onto the car, I am going to have very limited access to the back side of the repairs. What I WANT to do is treat/seal the back side of the repair which will be the most prone to be hit with moisture/debris from the tire. ![]() ![]() ![]() ![]() ![]() ![]() That said, here's my issue: I do not yet own a paint gun, nor epoxy primer. I'm going to Ospho the back side of this area and then I hoped to prime, seam seal, and undercoat it (do not care about not having body color back there--just want "tough") with the fender still unattached to the car. I know it's frowned upon but is there something in a rattle or brushable product I could treat the area with to make it impervious to the elememts later? |
| jonferns |
Jul 23 2011, 03:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
Stay away from POR, and the such. A good primer/paint/undercoating system will more than do the job. |
TargaToy Made some body parts Jul 23 2011, 10:07 AM
Andyrew Rust-oleum and por 15 can be applied with a paint ... Jul 23 2011, 10:41 AM
TargaToy Will rubberized undercoating stick to POR15? I ap... Jul 23 2011, 11:02 AM
rjames
Will rubberized undercoating stick to POR15? I a... Jul 23 2011, 02:09 PM
PanelBilly You need to make friends with the local body shop ... Jul 23 2011, 01:31 PM
Andyrew Rubberized undercoating will stick to anything....... Jul 23 2011, 02:24 PM
SirAndy Whatever you do, don't put POR15 over bare met... Jul 23 2011, 03:04 PM
saigon71
Had to create the transition from the driver... Jul 24 2011, 05:29 AM
rick 918-S Clean anything you can reach with a wire brush, us... Jul 24 2011, 06:32 AM
SirAndy POR= paint over rust. It does not bond well to cle... Jul 24 2011, 11:14 AM
TargaToy Thanks, Rick (and everybody else). I was really h... Jul 24 2011, 02:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:38 PM |
