oil cooler seals, small winter project |
914 shifter |
Jan 2 2011, 10:33 AM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
i am going to order a set of oil cooler seals from pelican.has anyone purchased these? pelican has an article on this subject/install.looks like a real pita, but i do believe i have a leak/drip in this area so i will order seals tomorrow.they are only $1 each i just want to be sure they are the best choice. assuming there is a choice. (IMG:style_emoticons/default/cheer.gif) happy new year!
type47 |
Aug 1 2011, 08:15 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I don't think you remove the cooler, just unbolt it enough to move the cooler away from the engine case to remove the old seals and install the new. You "can't" remove the cooler with the fan housing in place: if you really plan to remove the cooler, drop the engine, it will save time in the long run.
Lo-Fi Version | Time is now: 4th June 2024 - 11:38 AM |
