Zeke |
Never left, but not right.... ![]() ![]() Group: Members Posts: 392 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None ![]() |
I have Koni streets on the rear with the non adjustable perch for ride height. I want to lower the car. At this point, if I want to keep Konis, I have to buy yellow "sports" and smaller diameter (2 1/2 ID) springs and threaded collars to accomplish what I need.
After 15 months of construction, I am out of money, but the car is finished save for the rear springs. I just want to track it a couple of times before choosing new suspension stuff. I can't find any short stiff springs to lower the car with the Konis. So, I am thinking of cutting down some 160# stock height springs that came with the street Konis off a six conversion that wrecked. If I cut the springs and bend the wind at the base to fit in the perch better, I will have about a 185-190 short spring. That fits pretty well with my front 22mm T-bars. I could use some advice before I do this. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Just have a wet rag handy to cool the hot area after cutting. If you use a cut off wheel cool it partway through as well.
If you heat the end of the spring to make it conform better with the perch, you will lose the springiness from that part of the spring. |
Lo-Fi Version | Time is now: 13th July 2025 - 05:12 PM |
