| VaccaRabite |
Aug 7 2011, 02:30 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Weber 40, IDF carbs. Cable throttle linkage. They are NOT synched yet, and both carbs just had rebuilding work done. I've been working very slow due to time constraints. I fired up the car Friday night!!!
But it was idling at 3000rpm. After an hour, I had the idle down to 1800 rpm. Both idle adjusters were off the stops. Using a snail, one side was drawing a 7, the other a 14. When I turned off the car, I got a backfire. My "work hour" was done, so I had to leave it at that until the next time I can work - probably next Friday. So causes for the big idle that I need to investigate:
Where can I get the good base gaskets? The ones I have are from Weber Carbs Direct and they are the ultra crappy tan cardboard. They took a set and I am sure they are leaking like a sieve. Zach |
| anderssj |
Aug 7 2011, 03:17 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,782 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
Just checked the Carbs Unlimited site and found this:
40 IDF Base Gasket Dense fibrous, Anti-vibration paper need 2 per carb $3.67 ea about 2/3 down this page: http://www.carburetion.com/Weber/weberpartsjetkits.asp Steve A- |
Vacca Rabite Big idle Aug 7 2011, 02:30 PM
anderssj You might want to give David a call at Air Cooled ... Aug 7 2011, 03:08 PM
r_towle what "rebuilding work" did you do?
Its ... Aug 7 2011, 03:24 PM
Vacca Rabite Cleaned the jets and stacks. bored out the lead p... Aug 7 2011, 05:00 PM
jmill So causes for the big idle that I need to investig... Aug 7 2011, 05:54 PM
r_towle tighten them down at the heads and maniflod and re... Aug 7 2011, 06:42 PM
KaptKaos Are your air by pass screws all the way in? Aug 7 2011, 10:02 PM
SGB My car (40 idf, tall manifolds w/ isolators) does ... Aug 7 2011, 10:35 PM
Vacca Rabite I was about to discount the advice about checking ... Aug 8 2011, 06:02 AM
904svo Disconnect the throttle linkage, then using a flas... Aug 8 2011, 08:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:13 AM |
