FS- Extended Head Studs-SOLD, SOLD |
tornik550 |
Aug 8 2011, 08:51 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a set of used extended head studs from European Motorworks- $225 new. I had these on my engine for about 200 miles. I had to tear my engine down due to a few unrelated problems. When I decided to rebuild the engine, I changed it so I did not need jug spacers and therefore did not need extended head studs. These will work with a stock setup or with and engine that is wider than stock. If used in the stock configuration, they may need to be trimmed however I do not think they do.
http://www.europeanmotorworks.com/mm5/merc...-4-head-spacers One of the headstuds has a very slight bend because apparently when I had a headstud hole in my case repaired, it was repaired crooked- so when I torqued the stud, it put a slight bend in it. It should straighten out if put in and torqued correctly- however if you decided you wanted a new one- you can purchase one single stud from european motorworks for, IIRC $25. I think that I have most of the nuts but I am not certain- I would get new nuts. When I was posting this, I saw that I did not show all of the studs- I do have them and they look just like the others- it was just a photographic oversight. SOLD SOLD SOLD Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:37 AM |
