| draganc |
Aug 10 2011, 12:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
I’m installing a new battery tray and was wondering how the ECU mounting-bracket was originally connected to the battery tray? I have seen a few attached with screws and some are welded on?
Can anyone tell me what was original? Thanks, Dragan |
| type47 |
Aug 10 2011, 02:03 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
6mm hex head bolts are used. There are holes in the "front" edge of the battery tray (the edge toward the .... well, front of the car) and the bolts screw into the ECU bracket. I think the front bracket piece "bends" or curves over the end of the ECU and 2 6mm cheesehead screws connect the curved piece to the bracket that is attached to the tray. That way, you can remove the ECU, leaving the bracket in place when you drop the engine. There must be another fastener at the other end of the bracket or the ECU would flop/vibrate on the 2 screwed end.
draganc Battery tray Aug 10 2011, 12:36 PM
championgt1 Attached with screws. Aug 10 2011, 12:42 PM
SirAndy Attached with screws.
:agree: Aug 10 2011, 12:45 PM
draganc Thank you and Danke!
Any pictures? Aug 10 2011, 01:30 PM
draganc OK, let's make this idiot proof for me.
I can... Aug 10 2011, 02:56 PM
SirAndy Here a picture of what I have.
You are missing the... Aug 10 2011, 04:05 PM
draganc
You are missing th... Aug 10 2011, 06:45 PM
type47
[quote name='SirAndy' post='1522669' date='Aug 10... Aug 11 2011, 06:21 AM
draganc
OK, now we have the proof in the puding! Th... Aug 11 2011, 07:54 PM
SirAndy The braket I have is not original, it doesn't ... Aug 11 2011, 08:15 PM
r_towle That is correct Aug 10 2011, 02:59 PM
jsayre914 pics from a 73 2.0
Aug 10 2011, 03:25 PM
draganc PS: Can it be that there is a differance between l... Aug 10 2011, 06:52 PM
r_towle all of mine are held on with screws to the battery... Aug 11 2011, 07:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 05:03 AM |
