> 1st gear
bobp
post Jan 15 2003, 10:41 PM
I asked about this once before long ago and in a faraway place. My car has basically no first gear, I at this point assume it is the synchros. The car has a new clutch and clutch cable. I worked on the shifter alignment some and all the other gears shift fine.
First is almost impossible to engage, except at a very slow rolling speed. Stopped or downshifting to first while moving don't work. It also quite frequently pops out of first when releasing the clutch.
Is replacing the 1st gear synchros something that a fairly novice home mechanic can accomplish in a reasonable time.
This is the one project that has to get done for spring, it definitely takes away from driving enjoyment.
JWest
post Apr 14 2003, 12:02 PM
asigel - if it came on suddenly then it is probably not the syncros, they wear progressively. I would check the clutch adjustment first, and watch out for a stretching (and soon to be broken) clutch cable. Could also be your carpet under the clutch pedal!
bobp   1st gear   Jan 15 2003, 10:41 PM
campbellcj   I'm no mechanic, nor do I play one on TV, but ...   Jan 15 2003, 10:44 PM
bobp   Mine crunchs horribly and often can't be engag...   Jan 15 2003, 11:13 PM
Brad Roberts   One minor change: if the dog teeth are bad... it ...   Jan 16 2003, 12:18 AM
bobp   Brad, should I plan on replacing both the synchros...   Jan 16 2003, 10:18 AM
KenH   You can change 1st gear without removing the trans...   Jan 16 2003, 10:31 AM
Bleyseng   You can do the work yourself as its not too hard. ...   Jan 16 2003, 10:32 AM
Brad Roberts   Sorry I didnt get back sooner. You can do first g...   Jan 17 2003, 05:15 AM
Brad Roberts   Bob, You will need a end cover gasket. Dont buy t...   Jan 17 2003, 05:17 AM
Brad Roberts   Wayne wrote the first gear article, so there shoul...   Jan 17 2003, 05:21 AM
KenH   Brad, My mistake, I must have been thinking about...   Jan 17 2003, 10:51 AM
Brad Roberts   The way I wrote my reply, it appeared I was being ...   Jan 17 2003, 01:45 PM
asigel   I seem to be faced with the identical problem with...   Apr 10 2003, 12:29 PM
rhodyguy   ok , i looked at all the replies this time. my FIR...   Apr 11 2003, 07:07 PM
asigel   Hi Kevin She's a 73 1.7 side shifter. Until t...   Apr 14 2003, 11:07 AM
James Adams   asigel - if it came on suddenly then it is probabl...   Apr 14 2003, 12:02 PM
Brad Roberts   Check the firewall where the clutch tube exits the...   Apr 14 2003, 12:10 PM
Aaron Cox   pardon my incompetence (NO, im not FRENCH!...   Apr 14 2003, 04:40 PM
Bleyseng   Take a mini grinder with a cutting wheel and cut a...   Apr 14 2003, 06:38 PM
rhodyguy   by any chance have you checked the coupler where t...   Apr 14 2003, 07:31 PM
asigel   Hi Folks Thanks for the advice! I looked arou...   Apr 16 2003, 12:27 PM
- Lo-Fi Version Time is now: 6th July 2025 - 01:51 PM
