> Im ready to stick the tranny in, Need help finding info
weird_looking_cactus
post Apr 23 2004, 12:21 AM
Cactus
I got my self a tranny, Im going to attemp to stick it in tomarrow sence I don't have school. I only have access to basic tools at my house I have some jack stands Im going to use. I can't find any tech articals on replacing the tranny I have checked pelican to. So all I have is my haynes manuel. Here are some questions. This is a side shifter transmission.
1. Do I have to drop the engine to take the tranny out
2. Do I need any special tools
3. How long do you think it will take
4. Will this be possible with only 2 people and jack stands
5. Are there any articals out there to help me.
Im sure I will have plenty more once I start.
ArtechnikA
post Apr 23 2004, 05:04 AM
rich herzog
i'm confused.
you've read the procedure in the Haynes, right ?
more things to check:
do you have enough (5,3 US pints) 85W-90 gear oil?
if the new transmission is already out of a car, have you been able to remove & replace the drain and fill plugs (do -not- assume it'll have the proper amount of the correct lubricant) ?
do you have an appropriate CV joint grease for when you re-attach the CV's to the flanges ?
do you understand how to adjust a clutch and the gear selector ?
the consequences of not doing this stuff right can be serious - think about what happens when one of the halfshafts comes loose from the transmission while the car is on the highway. (hint - it's a 50-lb club being flung at high speed in the area of expensive stuff...)
weird_looking_cactus   Im ready to stick the tranny in   Apr 23 2004, 12:21 AM
Lawrence   1. No, and I wouldn't recommend it, for now. ...   Apr 23 2004, 12:48 AM
Eric Taylor   1) No. You just have to be strong, or be able to b...   Apr 23 2004, 12:51 AM
Lawrence   I just reread your post. Unless you keep a basic ...   Apr 23 2004, 12:57 AM
ArtechnikA   i'm confused. you've read the procedure i...   Apr 23 2004, 05:04 AM
weird_looking_cactus   In my manuel I it dosn't say have lots of extr...   Apr 23 2004, 10:06 AM
ArtechnikA
- Lo-Fi Version Time is now: 1st July 2025 - 06:28 AM
