> External oil cooler components
lmcchesney
post Apr 22 2004, 09:28 AM
I have reviewed the PP tech article and looked up the components. A few questions still need answers. Since you are placing a remote spin on oil filter, can you not use a larger capacity filter? Is there an advantage to the use of two filters, either in series or parallel? What is the optimal temperature for the oil thermostat to open flow to the oil cooler, 170° or 180°? MG makes a thermostat which flows at 170° at a lower price.
Images of the remote filter mount shows four fittings. However, for a flow through system, only two would be required. Are the other fittings for selection for linear left to right oil flow or the alternative of left to left flow? Since the fan is wired to produce air flow in a pull fashion (air flow through the cooler and then into the fan), do you not need to place spacers between mounting surface (rear trunk floor) and cooler? If so, what is the appropriate amount of space? The electrical thermostat is mounted via a T prior to the filter. Can this thermostat also provide an oil temp reading?
The use of NPT, JIC fittings are very neat. However, is there a problem with also using solid brass pip sittings where capable? Since the exposure of these lines are relatively protected, what is the down side of using non steel braided but re-enforced rubber lines? What is the down side of the use of barbed fittings with hose calmps? Can the entire system use 1/2" lines/connectors?
Thanks,
L. McChesney
lmcchesney
post Apr 23 2004, 06:40 AM
Thanks Brad. Despite others thoughts, I do appreciate years of experience.
It should not be that much of a problem. The fiberglass rockers are not riveted down as yet. I too was concerened with the quanity of head in the engine compartment. If it is enough to cause vapor lock 2-3 feet away, it probably would not provide enough temp differential. So, plumb to the front like the -6 GT style? Run _10 to the front? Cooler size 11 x 8.5 adaquate? Even up front, would it be helpful to place the pull fan on the cooler, i.e. could you get adaquate cooling with the smaller cooler?
Another option I have heard of is the GT flares. Mine has the 9" flares in the rear. Certainly enough room in there even if I put the 255's in there. This would provide a heat sheild between the cooler and engine compartment and would allow for short plumbing/wiring. I quess you would have to design a way to cover from mud/dirt from the tire. Have you seen this setup?
Thanks,
L. McC
The tech article on the Bird site:http://www.pelicanparts.com/techarticles/914_ext_oil_cooler/914_ext_oil_cooler.htm
- Lo-Fi Version Time is now: 4th July 2025 - 10:43 AM
