can i run 2.0 out of car without relay board?, & do i have these wires marked correctly ?? |
jimkelly |
Aug 17 2011, 08:44 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pic
Attached thumbnail(s) |
Mike Bellis |
Aug 17 2011, 09:13 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The relay in the 3rd pic looks like a hot start relay. You should be able to connect the FI wiring and a hot to the coil and ECU and it should start. You don't need the relay board.
r_towle |
Aug 17 2011, 09:19 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The relay in the 3rd pic looks like a hot start relay. You should be able to connect the FI wiring and a hot to the coil and ECU and it should start. You don't need the relay board. you will then be running off pure battery with no alternator....keep that in mind. Rich |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:36 AM |
