> Engine Temp Cooling Methods
p914
post Aug 12 2011, 10:52 AM
Would 2 1000 cfs fans in the engine compartment mounted on the firewall aimed downward (not an extreme angle) and at the rear of the engine cool engine temps?
What other methods besides Nickys, Shrouds, Radiators are there?
Dave_Darling
post Aug 17 2011, 05:57 PM
914 Idiot
Where are you going to run those hoses and the duct? Some 914 race cars duct air directly from the headlight buckets to the fan (evidently that rule was written for Brit Iron that needed some cooling help) but they usually do it through a large "sewer duct" through the cockpit.
--DD
p914   Engine Temp Cooling Methods   Aug 12 2011, 10:52 AM
johannes   First question you should ask yourself is why does...   Aug 12 2011, 11:12 AM
p914   A good question to ask. I should probably say thi...   Aug 12 2011, 11:20 AM
Vacca Rabite   240? That's not even operational temp. Heads ...   Aug 12 2011, 11:25 AM
p914   240? That's not even operational temp. Heads...   Aug 12 2011, 02:01 PM
Vacca Rabite   240? That's not even operational temp. Head...   Aug 12 2011, 05:33 PM
p914   For head temps, yes. Oil temps you don't wan...   Aug 12 2011, 06:01 PM
904svo   [quote name='Vacca Rabite' post='1523531' date='A...   Aug 12 2011, 06:35 PM
FourBlades   Mount an additional oil radiator with fans. Many ...   Aug 12 2011, 11:28 AM
Bartlett 914   Lean conditions also make the motor run hot.   Aug 12 2011, 11:52 AM
r_towle   The stock fan is only going to pull a certain amou...   Aug 12 2011, 11:54 AM
p914   Foley has created a new version of the top mounte...   Aug 12 2011, 01:32 PM
76-914   Would 2 1000 cfs fans in the engine compartment m...   Aug 12 2011, 07:12 PM
p914   Might want to get some ballast. Those 2 1000 cfs f...   Aug 12 2011, 08:11 PM
Jake Raby   I have a pair of the "twin barrel" upper...   Aug 12 2011, 07:59 PM
Jake Raby   But at very little velocity.. Electric solutions a...   Aug 12 2011, 08:32 PM
SGB   I've wondered about something simple- scoop li...   Aug 12 2011, 10:22 PM
Joe Owensby   As someone mentioned, check your timing. Also, wi...   Aug 15 2011, 06:29 PM
904svo   Here is how I cooled my 914 engine.   Aug 15 2011, 07:28 PM
p914   I have an external oil cooling system I'm look...   Aug 15 2011, 10:16 PM
p914   So as I was driving today I thought about my front...   Aug 17 2011, 04:56 PM
yeahmag   Ducting it right in to the tin is a bad idea in my...   Aug 17 2011, 05:41 PM
Dave_Darling   Where are you going to run those hoses and the duc...   Aug 17 2011, 05:57 PM
aircooledtechguy   I've always found that when you build/tune a m...   Aug 17 2011, 06:08 PM
69telecaster   Front air dam holes are small and a long way from ...   Aug 19 2011, 07:58 AM
p914   Nice lookin car Telly   Aug 19 2011, 01:55 PM
ellisor3   Here is what Joe at 914rs came up with for my six....   Aug 19 2011, 02:07 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:55 PM
