/6 Dash Switch Order |
RiqueMar |
Aug 18 2011, 07:13 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Does anyone have a picture of the order in which the switches are located on the Dash of a /6? I can't seem to find a stock orientation anywhere!
toolguy |
Aug 19 2011, 09:43 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The stock wires wont be long enough to get the hazard switch over to the right side of the steering wheel .
On my 6 , after I pulled the wiring harness, I put it back and when placing the switches, found that the hazard switch 'wanted' to go next to the headlight switch and the fogs naturally went next to the ignition switch. . . That was because that's where the harness wires fit the best. . . I tried to put them in the stock location but the wiring had to be pulled and bent. so I put them where it 'felt' best. . . As for the defroster switch. . . it's a perfect candidate for a fuel pump cut-off switch. . . serves 2 purposes. . . 1- in case of fire. . 2nd- it's a great anti theft item. . just run 2 wires over to the fuel pump and intercept the positive lead at the pump. . so with the switch in it wont start. . you'll have to pull it out to start the car. . |
RiqueMar |
Aug 19 2011, 09:56 AM
The stock wires wont be long enough to get the hazard switch over to the right side of the steering wheel . On my 6 , after I pulled the wiring harness, I put it back and when placing the switches, found that the hazard switch 'wanted' to go next to the headlight switch and the fogs naturally went next to the ignition switch. . . That was because that's where the harness wires fit the best. . . I tried to put them in the stock location but the wiring had to be pulled and bent. so I put them where it 'felt' best. . . Agreed. I'm running everything to the stock locations, and once finished/tested, then I'll start modifying a bit (integrating the /6 ignition, disconnecting the fogs from the headlights, fuel pump, moving over the Hazard switch, etc) I've already had to pull a few mods to get this back to the stock diagram. Whoever the previous owner was, whenever they fixed a connection, I suppose they didn't see fit to color-coordinate, label, or even use the correct year wire, So I've been pulling wires from other harnesses to maintain accuracy. As for the defroster switch. . . it's a perfect candidate for a fuel pump cut-off switch. Lol, well, there goes my secret! |
Lo-Fi Version | Time is now: 9th June 2024 - 06:54 PM |
