> Still Vibrating...
MikeM
post Aug 19 2011, 12:54 PM
Hello all...I recently posted about a vibration I'm having at 30 and 60mph.
I have some new information to share and some more questions.
I purchased the hub centering rings from Chris Foley and they made no difference.
Today I took the car to my mechanic's shop and we put it on a hoist and I ran it up to 70mph. The shake/vibration was still there!! So, it's obviously NOT in the front end. Mechanice says he's pretty sure the shaking stopped when I put the trans in neutral and turned off the engine. Although that could be a function of the speed reducing also.
So, where to look now? Flywheel? CV joints/axles?
Car is a 74 2.0 liter.
Thanks as always...
Mike
MikeM
post Aug 19 2011, 07:07 PM
Sorry...I wasn't clear.
I was asking if it's possible to remove the Axle shafts without removing the heat exchangers. Is there enough room to get them out using your method?
Cheers
Mike
MikeM   Still Vibrating...   Aug 19 2011, 12:54 PM
smontanaro   Probably not the first place to look, but many peo...   Aug 19 2011, 01:12 PM
MikeM   Good thoughts...NO vibration when revving in the g...   Aug 19 2011, 01:26 PM
SirAndy   Must be something in the trans or CV joints and sh...   Aug 19 2011, 01:34 PM
914Mels   How about shifting into neutral at the vibration s...   Aug 19 2011, 01:37 PM
MikeM   Yup...clutch and flywheel are on the "suspect...   Aug 19 2011, 01:44 PM
SirAndy   Motor mounts look new. How can you tell? They are ...   Aug 19 2011, 01:59 PM
76-914   Jack it up with one rear wheel on the ground and t...   Aug 19 2011, 01:48 PM
MikeM   Sir Andy....to be honest, I'm not sure. I was ...   Aug 19 2011, 02:08 PM
r_towle   There are a few bearings inside the transmission t...   Aug 19 2011, 03:37 PM
SUNAB914   How about front wheel bearings? Make sure theyt ar...   Aug 19 2011, 04:02 PM
Ductech   If the clutch and or flywheel was imbalanced would...   Aug 19 2011, 05:57 PM
r_towle   his test on a lift eliminates both the front end b...   Aug 19 2011, 06:00 PM
MikeM   Thanks Rich...here's a related question... Is ...   Aug 19 2011, 06:20 PM
r_towle   yes, you can pull the gear stack in the tranny wit...   Aug 19 2011, 06:41 PM
MikeM   Sorry...I wasn't clear. I was asking if it...   Aug 19 2011, 07:07 PM
SirAndy   I was asking if it's possible to remove the Ax...   Aug 19 2011, 07:52 PM
MikeM   Thank you Sir...I think that will be my next chore...   Aug 19 2011, 09:06 PM
larss   I had a similar problem with my 914. It turned out...   Aug 19 2011, 11:09 PM
willamp   I had a vibration in my car recently and the probl...   Aug 20 2011, 07:38 AM
MikeM   Thanks gents...obviously I have a few things to in...   Aug 20 2011, 08:06 AM
MikeM   I'll bump this in case anyone has any ideas......   Aug 21 2011, 01:50 PM
- Lo-Fi Version Time is now: 1st July 2025 - 04:32 AM
