> Still Vibrating...
MikeM
post Aug 19 2011, 12:54 PM
Hello all...I recently posted about a vibration I'm having at 30 and 60mph.
I have some new information to share and some more questions.
I purchased the hub centering rings from Chris Foley and they made no difference.
Today I took the car to my mechanic's shop and we put it on a hoist and I ran it up to 70mph. The shake/vibration was still there!! So, it's obviously NOT in the front end. Mechanice says he's pretty sure the shaking stopped when I put the trans in neutral and turned off the engine. Although that could be a function of the speed reducing also.
So, where to look now? Flywheel? CV joints/axles?
Car is a 74 2.0 liter.
Thanks as always...
Mike
MikeM
post Aug 19 2011, 09:06 PM
Thank you Sir...I think that will be my next chore.
Mike
MikeM   Still Vibrating...   Aug 19 2011, 12:54 PM
smontanaro   Probably not the first place to look, but many peo...   Aug 19 2011, 01:12 PM
MikeM   Good thoughts...NO vibration when revving in the g...   Aug 19 2011, 01:26 PM
SirAndy   Must be something in the trans or CV joints and sh...   Aug 19 2011, 01:34 PM
914Mels   How about shifting into neutral at the vibration s...   Aug 19 2011, 01:37 PM
MikeM   Yup...clutch and flywheel are on the "suspect...   Aug 19 2011, 01:44 PM
SirAndy   Motor mounts look new. How can you tell? They are ...   Aug 19 2011, 01:59 PM
76-914   Jack it up with one rear wheel on the ground and t...   Aug 19 2011, 01:48 PM
MikeM   Sir Andy....to be honest, I'm not sure. I was ...   Aug 19 2011, 02:08 PM
r_towle   There are a few bearings inside the transmission t...   Aug 19 2011, 03:37 PM
SUNAB914   How about front wheel bearings? Make sure theyt ar...   Aug 19 2011, 04:02 PM
Ductech   If the clutch and or flywheel was imbalanced would...   Aug 19 2011, 05:57 PM
r_towle   his test on a lift eliminates both the front end b...   Aug 19 2011, 06:00 PM
MikeM   Thanks Rich...here's a related question... Is ...   Aug 19 2011, 06:20 PM
r_towle   yes, you can pull the gear stack in the tranny wit...   Aug 19 2011, 06:41 PM
MikeM   Sorry...I wasn't clear. I was asking if it...   Aug 19 2011, 07:07 PM
SirAndy   I was asking if it's possible to remove the Ax...   Aug 19 2011, 07:52 PM
MikeM   Thank you Sir...I think that will be my next chore...   Aug 19 2011, 09:06 PM
larss   I had a similar problem with my 914. It turned out...   Aug 19 2011, 11:09 PM
willamp   I had a vibration in my car recently and the probl...   Aug 20 2011, 07:38 AM
MikeM   Thanks gents...obviously I have a few things to in...   Aug 20 2011, 08:06 AM
MikeM   I'll bump this in case anyone has any ideas......   Aug 21 2011, 01:50 PM
- Lo-Fi Version Time is now: 1st July 2025 - 04:17 AM
