Location for Oil Breather/Puke Can, Will This Work? |
kconway |
Aug 18 2011, 09:46 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Can someone confirm I won't have interference with the motor with the breather can in this location? Not sure I can get the hose to mate up to the oil filler neck though (IMG:style_emoticons/default/blink.gif)
Kev |
kconway |
Aug 24 2011, 06:10 AM
I bought the breather from Jegs.com part number 52203. It's comes with a AN 10 x -12 flare union on the can, I had to source the 90.
http://www.jegs.com/webapp/wcs/stores/serv...;itemPerPage=90 Here is the can fully plumbed in the above location. I am not using my rear trunk lid torsion bars so I fabbed a bracket that hangs down behind the can and picks up the two mounting studs on top that use to clamp the torsion bar. The petcock is now plumbed down through the engine shelf for emptying the can. I might redo the fitting at the filler neck. I slit the filler neck so I could get clamping pressure on the plastic elbow fitting that the rubber hose is attached to. I've got a weld on AN -12 bung on the way to replace that connection with another AN -12 elbow but that might be overkill for what it does. Kev |
Lo-Fi Version | Time is now: 10th June 2024 - 03:39 AM |
