75 914 1.8 FI won't start |
PBC914 |
Aug 27 2011, 09:39 PM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
I have a 75 1.8 with FI that won't start. This problem started after I took it for a long run yesterday and the engine got pretty hot (almost in red) on the temp gauge. Not sure if that is part of it.
When I turn the key to "on" I don't hear the fuel pump run. But, when I try to turn it over, I can hear the fuel pump running/I know the pump is getting electricity. Does the fuel pump need to run initially before startup? I swear I have always heard it before starting the car. Any ideas? |
Valy |
Aug 28 2011, 01:49 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Seems your AAR is close.
Take out the vacuum hose between the AAR and the Y splitter close to the air box. Plug the Y and check that you have vacuum through the AAR. If not, it doesn't work. |
Lo-Fi Version | Time is now: 4th June 2024 - 03:36 PM |
