Relay Board Replacement, on a Carbed 4cyl Application |
texag09 |
Aug 30 2011, 09:37 AM
Member Group: Members Posts: 72 Joined: 9-February 11 From: Houston, TX Member No.: 12,683 Region Association: Southwest Region |
Running carbs on a 4cy is there any need to keep the relay board or could it be replaced, with something cleaner and more modern.
What I know the relay board does. 1. Voltage Regulator for alternator (could I make a custom mount for the voltage regulator?) 2.Rear Window Blower (not used) 3. Heater blower realy (not used) 4. Fuel pump relay (not used in my application of switched and fused pump) 5. Fuses for blowers and pump (not used) Comments? Have you done it? What does it require? Any adapters for the regulator? |
Valy |
Aug 30 2011, 11:18 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
4. Fuel pump relay (not used in my application of switched and fused pump) (IMG:style_emoticons/default/new_shocked.gif) Had you ever consider that in an accident you'll forget or bee unable to switch off the pump?!?! It may pump fuel over a ripped wire that might just ignite it! Always have a relay that automatically shuts off the fuel pump! |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:34 AM |
