| jsayre914 |
Sep 2 2011, 09:52 AM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
So my daily driver is now dead on number 3
Engine : Bone stock 1.8 liter w/ L-jet (1974) 2 days ago I am driving as usuall, pushing it pretty hard 4k rpm for about an hour in 5th gear, i notice a loss of power, number three is dead. I pull the plug wire while running and no difference. so I park it overnight and do a valve adjustment in the morning. Number 3 is still dead. I pull the plug and look at it. It is black as hell and not shiny or oily. dull black. I pop in a new plug. still dead. I switch the injector leads from front to back. still #3. I swap injectors from the same side. still #3 this means no compression right? I (IMG:style_emoticons/default/blink.gif) just did the adjustment the night before and it was .006 on intake and exhaust. How can the adjustment be perfect and the cylinder be dead.??? (IMG:style_emoticons/default/confused24.gif) last note: on the dead cylinder, if i pull the injector lead from that one, the rpm drop fatally as if it were only running on 2. but as i said it makes no difference if the plug wire is on or not. What gives?? (IMG:style_emoticons/default/ar15.gif) i guess the motor is comming out again, but what am i looking for (IMG:style_emoticons/default/icon8.gif) |
| r_towle |
Sep 2 2011, 11:59 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Have you checked that your number 3 spark plug is firing by grounding out the body of the plug while cranking the motor?
How is the distributor cap? How is the rotor? How are the grounds for the injectors? Are you getting fuel at that injector? Sounds like it may be less complicated???? Rich |
jsayre914 Number 3 is dead thread Sep 2 2011, 09:52 AM
Vacca Rabite Compression test. But you know what it is gong to ... Sep 2 2011, 11:01 AM
Drums66
Compression test. But you know what it is gong to... Sep 2 2011, 11:32 AM
underthetire Was the #3 exhaust valve adjuster further out than... Sep 2 2011, 11:40 AM
markb Plug wire? Sep 2 2011, 12:44 PM
jsayre914 engine is knocking.
plug is new, wire gives a goo... Sep 2 2011, 12:55 PM
Dave_Darling How does the starter sound? If you really do have... Sep 2 2011, 07:05 PM
Dr Evil Having had my hands on and in that 1.8 of your, I ... Sep 3 2011, 07:55 PM
jsayre914
stop pissing away time and money on that tired 1.... Sep 4 2011, 09:01 AM
hot_shoe914
stop pissing away time and money on that tired 1... Sep 4 2011, 09:25 AM
saigon71 Excellent! :beer2: I look forward to the 205... Sep 4 2011, 11:55 AM
jsayre914 Thank you Zach (Vaca Rabbite) and Mike (Kirmizi)
... Sep 5 2011, 10:39 AM
Kirmizi Next time Joe! Or better yet, have the 2056 b... Sep 5 2011, 08:25 PM
jsayre914
this means no compression right? I :blink: jus... Oct 5 2011, 09:46 AM
jsayre914 dead again.... :( .... 300 miles later.
<_... Oct 10 2011, 11:10 AM
Vacca Rabite Joe is brave. I have off and offered to tow him ho... Oct 10 2011, 12:50 PM
jsayre914
but he elected to drive her back on 3.
again ... Oct 10 2011, 01:35 PM
jsayre914 :idea: Do you guys think its possible to adjust th... Oct 10 2011, 02:39 PM
Vacca Rabite Dude.
You got 300 miles last time.
Its done. Pul... Oct 10 2011, 04:12 PM
jsayre914
Dude.
Its done. Pu... Oct 10 2011, 04:20 PM
Dr Evil Nah, just put a few of these on :rolleyes: Oct 10 2011, 04:22 PM
jsayre914
Thank... Oct 10 2011, 04:32 PM
Dr Evil Um, ya I know. I helped once. Remember? :toke: :bl... Oct 10 2011, 09:09 PM
jsayre914 The numbers of the day....
Chamber 1 98
Cham... Oct 11 2011, 01:04 PM
jsayre914
Chamber 1 98
Cha... Dec 15 2011, 01:04 PM
Vacca Rabite You probably need the fuel pump, unless you still ... Oct 11 2011, 03:53 PM
jsayre914 c'mon guys...
Burnt valve?
Broken valve?
Sea... Dec 16 2011, 03:04 PM
Vacca Rabite I need the parts when you pull the engine, which I... Dec 16 2011, 07:03 PM
Vacca Rabite Oh, and the bum compression may be a valve seat th... Dec 16 2011, 07:04 PM
Dr Evil Are these #s on the same tired 1.8? Dec 17 2011, 12:59 AM
messix broken rings/ring lands will bleed off compression... Dec 17 2011, 01:28 AM
jsayre914 YUP!
Im DONE !!
This engine has retir... Dec 27 2011, 08:22 PM
Dr Evil Was this the 2056? Dec 27 2011, 08:38 PM
jsayre914
Was this the 2056?
NO
This was the latest ban... Dec 27 2011, 08:50 PM
Dr Evil
Was this the 2056?
NO
This was the latest ba... Dec 27 2011, 09:33 PM
Vacca Rabite Ahem....
Told ya so. :-)
Zach Dec 27 2011, 09:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th March 2026 - 04:09 AM |
