badboybear |
Member ![]() ![]() Group: Members Posts: 70 Joined: 27-January 11 From: Salem, OR Member No.: 12,632 Region Association: None ![]() |
[size=3]How high do I need jack the car up to take the engine out from the bottom? Does anyone have a diagram for removing the engine....what bolts & where to remove, want to drop tranny & motor at once...hopefully.
Also where do I look or go to get a "repair kit" for the HELL HOLE. Told there is a metal replacment type piece? Thanks all, M&T914 |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
with carbs on a 4 if you remove the carbs as an assembly leaving the linkage intact you'll buy yourself a bunch of room and preserve your current linkage adjustment. remove the 8 nuts securing the carbs to the intakes, disconnect the throttle cable, lift carbs off, and a paper towel in each runner to keep stray items out of the engine.
k |
Lo-Fi Version | Time is now: 11th July 2025 - 09:07 AM |
