Easy/cheap battery cutoff?, To speed up disconnect |
BigDBass |
Sep 23 2011, 12:34 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Is there a "go to" solution for a quick battery disconnect? I've seen some for race cars, but I'm just looking for something in the engine bay in line with battery wiring to make it quick and easy to disconnect the battery when working on the car, flat towing, etc. Any recommendation for part and source would be appreciated. Dan |
pcar916 |
Sep 23 2011, 01:19 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I'd advise against any of the cheap solutions. My car had the "green knob" on it for about 6 months when I bought it. It got increasingly corroded and gave me flakey results for a while until it just broke altogether. Use this one if you want to be kind to your alternator and diodes... not to mention the ECU if your car has one.
http://www.racerpartswholesale.com/product...ery_Disconnects |
flipb |
Sep 23 2011, 01:36 PM
Senior Member Group: Members Posts: 1,728 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
I'd advise against any of the cheap solutions. My car had the "green knob" on it for about 6 months when I bought it. It got increasingly corroded and gave me flakey results for a while until it just broke altogether. Use this one if you want to be kind to your alternator and diodes... not to mention the ECU if your car has one. http://www.racerpartswholesale.com/product...ery_Disconnects Hmm, guess it's a YMMV situation. I've had the green knob since I bought the car 2 years ago (and who knows how long it was on before I bought it) with no trouble... no visible corrosion and no electrical issues. (Other than forgetting to re-tighten it after I've left the car parked for a while.) (IMG:style_emoticons/default/smile.gif) |
pcar916 |
Sep 23 2011, 01:50 PM
(Other than forgetting to re-tighten it after I've left the car parked for a while.) (IMG:style_emoticons/default/smile.gif) Oh yeah, I did that plenty of times. It falls under the same heading as leaving your steering wheel in the house. But the corrosion wasn't something I could see unless I took the thing apart. It simply got increasingly tough to screw it down hard enough to make good contact. Sidenote: You can get a battery cutoff from Pegasus, Summit, or any of the other normal racing outlets. But the pricing is nearly always better at Racer Parts Wholesale. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:51 PM |
