Where can I get something to fill this hole?, Lost the damn thing somewhere in my garage. |
root |
Sep 24 2011, 08:09 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
Anybody got a plug for this huge hole in my case?
or where to get a new one? and what size thread is it? Lost the damn thing somewhere in my garage.(IMG:style_emoticons/default/confused24.gif) |
type47 |
Sep 24 2011, 08:43 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
ignore the green arrows, pic I had of plugs with something in your hole (IMG:style_emoticons/default/huh.gif)
root |
Sep 24 2011, 08:53 PM
Valy |
Sep 24 2011, 10:03 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Happy you found the plug size but I think that the one you have now will interfere with the engine mount. The oil port out of the type 1 oil pump might make trouble with the other motor mount.
I'm looking for an oil pump for my motor. Which oil pump you got there? is it steel or aluminum body? |
root |
Sep 25 2011, 06:40 AM
Happy you found the plug size but I think that the one you have now will interfere with the engine mount. The oil port out of the type 1 oil pump might make trouble with the other motor mount. I'm looking for an oil pump for my motor. Which oil pump you got there? is it steel or aluminum body? 26mm Type 1 oil pump (plugged) for remote filter (as I'm putting this engine on a bike). The pump is aluminum from Aircooled.net. Since I know the thread size now I'll order a stainless hex plug from mcmaster: http://www.mcmaster.com/#stainless-steel-p...nd-pipe/=e7qy6p $2.40. (IMG:style_emoticons/default/biggrin.gif) |
nathansnathan |
Sep 26 2011, 07:05 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
Happy you found the plug size but I think that the one you have now will interfere with the engine mount. The oil port out of the type 1 oil pump might make trouble with the other motor mount. I'm looking for an oil pump for my motor. Which oil pump you got there? is it steel or aluminum body? 26mm Type 1 oil pump (plugged) for remote filter (as I'm putting this engine on a bike). The pump is aluminum from Aircooled.net. Since I know the thread size now I'll order a stainless hex plug from mcmaster: http://www.mcmaster.com/#stainless-steel-p...nd-pipe/=e7qy6p $2.40. (IMG:style_emoticons/default/biggrin.gif) The difference is that the plug I got actually fit the threads. McMaster doesn't sell very much metric stuff. Also, stainless is not your friend when it comes to stuff like this, expands too much with heat. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:13 PM |
