| MrHyde |
Sep 27 2011, 04:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
So.... in order to get a bit more room in the garage after the move, so I can start welding on the body i figured I'd work on getting the engine up on a stand an off to the side for a little bit... I have the tranny off and wires/FI stripped off and boxed up and have been taking the sheet metal screws off.. I have 4 that are totally seized on... 3 of them at the intake ports and one on the fan shroud.. I've soaked them with pb blaster and all i've managed to do it mangle the slot in the screw a bit..
I'm inclined to just drill out the screws and tap them afterwards... Before I do this, does anyone have any time tested suggestions to get these buggers off?? If not, does anyone know off hand what size the tap / drill I'll need to use ? Thanks ! Mike |
| Jeffs9146 |
Sep 27 2011, 04:33 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I had the same problem and after 3 days of PB I heated them with a torch and used a pair of Vice Grip Plyers and the screw driver at the same time using the wrench more than the screw driver!
3 came out no problem but one broke off in the head. I gave the heads away any way so I never looked at them again! So try the torch heat and vice grip method and take your time letting the PB soak in! |
MrHyde Seized engine sheet metal screws Sep 27 2011, 04:24 PM
Vacca Rabite if you have an impact driver you could try tapping... Sep 27 2011, 04:29 PM
nathansnathan I would try grabbing the head with vise grips befo... Sep 27 2011, 04:32 PM
tradisrad A big screw driver that does not slip/strip out al... Sep 27 2011, 04:37 PM
Eric_Shea MAPP Torch. Sep 27 2011, 04:42 PM
MrHyde I just sprayed them (again ) with PB Blaster.. I... Sep 27 2011, 04:51 PM
wingnut86 I love PB, it runs through my veins nowadays :head... Sep 27 2011, 05:54 PM
bigkensteele I just went through this a couple of weeks ago. I... Sep 27 2011, 05:55 PM
r_towle Impact screw driver was invented to take out slott... Sep 27 2011, 06:11 PM
Dave_Darling I found that having the actual correct size of scr... Sep 27 2011, 09:56 PM
majkos
I found that having the actual correct size of sc... Sep 27 2011, 10:10 PM
vsg914 I'm another for the impact. If you dont have o... Sep 28 2011, 04:53 AM
Gint Last time I removed tin, and impact screwdriver go... Sep 28 2011, 05:45 AM
larss Had the same problem some weeks ago, a heat gun wo... Sep 28 2011, 07:41 AM
sean_v8_914 most of the advice above is solid. patience is the... Sep 28 2011, 07:53 AM
dlestep ...I have a special tool just for that. A B I G f... Sep 28 2011, 08:33 AM
mikea100 I had the same problem. It took 2 people, my buddy... Sep 28 2011, 08:50 AM
sean_v8_914 teamwork! love it Sep 28 2011, 09:04 AM
GeorgeRud I've also had better luck using Kroil as a pen... Sep 28 2011, 11:13 AM
MrHyde Final verdict... Maap torch, pb blaster and impact... Oct 7 2011, 01:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 05:22 AM |
