| MrHyde |
Sep 27 2011, 04:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
So.... in order to get a bit more room in the garage after the move, so I can start welding on the body i figured I'd work on getting the engine up on a stand an off to the side for a little bit... I have the tranny off and wires/FI stripped off and boxed up and have been taking the sheet metal screws off.. I have 4 that are totally seized on... 3 of them at the intake ports and one on the fan shroud.. I've soaked them with pb blaster and all i've managed to do it mangle the slot in the screw a bit..
I'm inclined to just drill out the screws and tap them afterwards... Before I do this, does anyone have any time tested suggestions to get these buggers off?? If not, does anyone know off hand what size the tap / drill I'll need to use ? Thanks ! Mike |
| tradisrad |
Sep 27 2011, 04:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
A big screw driver that does not slip/strip out always helps. Bolt extractor set may be helpful.
MrHyde Seized engine sheet metal screws Sep 27 2011, 04:24 PM
Vacca Rabite if you have an impact driver you could try tapping... Sep 27 2011, 04:29 PM
nathansnathan I would try grabbing the head with vise grips befo... Sep 27 2011, 04:32 PM
Jeffs9146 I had the same problem and after 3 days of PB I he... Sep 27 2011, 04:33 PM
Eric_Shea MAPP Torch. Sep 27 2011, 04:42 PM
MrHyde I just sprayed them (again ) with PB Blaster.. I... Sep 27 2011, 04:51 PM
wingnut86 I love PB, it runs through my veins nowadays :head... Sep 27 2011, 05:54 PM
bigkensteele I just went through this a couple of weeks ago. I... Sep 27 2011, 05:55 PM
r_towle Impact screw driver was invented to take out slott... Sep 27 2011, 06:11 PM
Dave_Darling I found that having the actual correct size of scr... Sep 27 2011, 09:56 PM
majkos
I found that having the actual correct size of sc... Sep 27 2011, 10:10 PM
vsg914 I'm another for the impact. If you dont have o... Sep 28 2011, 04:53 AM
Gint Last time I removed tin, and impact screwdriver go... Sep 28 2011, 05:45 AM
larss Had the same problem some weeks ago, a heat gun wo... Sep 28 2011, 07:41 AM
sean_v8_914 most of the advice above is solid. patience is the... Sep 28 2011, 07:53 AM
dlestep ...I have a special tool just for that. A B I G f... Sep 28 2011, 08:33 AM
mikea100 I had the same problem. It took 2 people, my buddy... Sep 28 2011, 08:50 AM
sean_v8_914 teamwork! love it Sep 28 2011, 09:04 AM
GeorgeRud I've also had better luck using Kroil as a pen... Sep 28 2011, 11:13 AM
MrHyde Final verdict... Maap torch, pb blaster and impact... Oct 7 2011, 01:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 05:24 AM |
