> Seized engine sheet metal screws, Better ask before I break out the drill
MrHyde
post Sep 27 2011, 04:24 PM
So.... in order to get a bit more room in the garage after the move, so I can start welding on the body i figured I'd work on getting the engine up on a stand an off to the side for a little bit... I have the tranny off and wires/FI stripped off and boxed up and have been taking the sheet metal screws off.. I have 4 that are totally seized on... 3 of them at the intake ports and one on the fan shroud.. I've soaked them with pb blaster and all i've managed to do it mangle the slot in the screw a bit..
I'm inclined to just drill out the screws and tap them afterwards...
Before I do this, does anyone have any time tested suggestions to get these buggers off?? If not, does anyone know off hand what size the tap / drill I'll need to use ?
Thanks !
Mike
MrHyde
post Sep 27 2011, 04:51 PM
I just sprayed them (again ) with PB Blaster.. I'll let them soak another night and get some oxygen for my maap torch tomorrow... thanks for the ideas
MrHyde   Seized engine sheet metal screws   Sep 27 2011, 04:24 PM
Vacca Rabite   if you have an impact driver you could try tapping...   Sep 27 2011, 04:29 PM
nathansnathan   I would try grabbing the head with vise grips befo...   Sep 27 2011, 04:32 PM
Jeffs9146   I had the same problem and after 3 days of PB I he...   Sep 27 2011, 04:33 PM
tradisrad   A big screw driver that does not slip/strip out al...   Sep 27 2011, 04:37 PM
Eric_Shea   MAPP Torch.   Sep 27 2011, 04:42 PM
MrHyde   I just sprayed them (again ) with PB Blaster.. I...   Sep 27 2011, 04:51 PM
wingnut86   I love PB, it runs through my veins nowadays :head...   Sep 27 2011, 05:54 PM
bigkensteele   I just went through this a couple of weeks ago. I...   Sep 27 2011, 05:55 PM
r_towle   Impact screw driver was invented to take out slott...   Sep 27 2011, 06:11 PM
Dave_Darling   I found that having the actual correct size of scr...   Sep 27 2011, 09:56 PM
majkos   I found that having the actual correct size of sc...   Sep 27 2011, 10:10 PM
vsg914   I'm another for the impact. If you dont have o...   Sep 28 2011, 04:53 AM
Gint   Last time I removed tin, and impact screwdriver go...   Sep 28 2011, 05:45 AM
larss   Had the same problem some weeks ago, a heat gun wo...   Sep 28 2011, 07:41 AM
sean_v8_914   most of the advice above is solid. patience is the...   Sep 28 2011, 07:53 AM
dlestep   ...I have a special tool just for that. A B I G f...   Sep 28 2011, 08:33 AM
mikea100   I had the same problem. It took 2 people, my buddy...   Sep 28 2011, 08:50 AM
sean_v8_914   teamwork! love it   Sep 28 2011, 09:04 AM
GeorgeRud   I've also had better luck using Kroil as a pen...   Sep 28 2011, 11:13 AM
MrHyde   Final verdict... Maap torch, pb blaster and impact...   Oct 7 2011, 01:17 PM
- Lo-Fi Version Time is now: 30th April 2026 - 06:23 AM
