> Relay Board Wiring Mess, PO's Rewire - Need A Little Help
bandjoey
post Sep 25 2011, 09:00 PM
bandjoey
The PO cut the Yellow Wire where it comes from below the relay board up to the pin connector and spliced on a 12" red wire, (#1)and then taped off the end, so it's a dead wire. (IMG:style_emoticons/default/blink.gif)
He then added a red wire from the ignition switch, through the firewall, (#2) and tied it into the yellow wire going into the wire harness moving down towards the starter.
What would I do to make this right?
It's a '73 original 1.7, switched by the PO to a 1.8 with carbs, and I'm switching that to a 2.0 with carbs and want to get the red wire off the ignition switch.
Also, in the other picture, he cut off a Blue wire and taped it off. Where does this go and what does it do and do I need it?
rnellums
post Sep 28 2011, 09:52 AM
Professional Enthusiast
How is your build coming? chances at making MUSR? Also, I have two complete wiring harnesses from a 73 and a 74 if that would help you. They are just taking up space in my basement.
-Ross
- Lo-Fi Version Time is now: 2nd April 2026 - 03:30 PM
