> High Mileage EA motor teardown, 330,000 miles +
mgphoto
post Sep 28 2011, 05:56 PM
"If there is a mistake it will find me"
The time has come to rebuild the original EA motor in my '72.
I am most of the way though teardown, I will add some photos of the worn parts in a later post.
I am trying to figure out the size of the tool to use to remove this fastener, the cover for the second oil pressure relief piston and spring.
Factory service manual has it as M14 internal head socket. I searched for it but all I could find is the AST Tool # S 54 X-14 at the link listed below
http://www.asttool.com/detail_page.php?too...r=S%2054%20X-14
Does anyone know if this is the correct tool?
Thanks for looking,
Mike
TheCabinetmaker
post Sep 28 2011, 06:24 PM
I drive my car everyday
You are correct. Its called a tripple square, among other things. Available at oriellys. M14 is the size
mgphoto
post Sep 28 2011, 09:36 PM
QUOTE(vsg914 @ Sep 28 2011, 05:24 PM) *
Hey vsg914,
Just got back from O'Reilly's "all we have is what's on the shelf" I live in Los Angeles, very difficult to find anything here. They did not have it, but they did have a Lisle 62200, it is used to remove broken heater hose couplers on GM cars, fits perfectly!
Thanks everyone,
Mike
mgphoto   High Mileage EA motor teardown   Sep 28 2011, 05:56 PM
vsg914   If I recall correctly, its the same tool you use f...   Sep 28 2011, 06:06 PM
mgphoto   Hey vsg914, just checked and the axle tool is much...   Sep 28 2011, 06:15 PM
RON S.   When I needed an internal 12pt tool for my CV...   Sep 28 2011, 06:20 PM
'73-914kid   3/8 inch drive socket extension worked for me....i...   Sep 28 2011, 06:20 PM
vsg914   You are correct. Its called a tripple square, amon...   Sep 28 2011, 06:24 PM
mgphoto   You are correct. Its called a tripple square, amo...   Sep 28 2011, 09:36 PM
rick 918-S   Wow! 330K? Very cool! :popcorn:   Sep 28 2011, 09:50 PM
76-914   Wow! 330K? Very cool! :popcorn: That...   Sep 29 2011, 04:48 PM
McMark   Yup, never used anything but a 3/8" drive ext...   Sep 28 2011, 11:17 PM
mgphoto   I ran into a small snag, trying to remove the head...   Sep 29 2011, 12:25 PM
Jake Raby   To remove that triple square fastener give it two ...   Sep 29 2011, 05:12 PM
mgphoto   I bought the car in the '80's, 96k on the ...   Sep 30 2011, 06:46 PM
Valy   Pulled the motor at 337,xxx broke 2 angle drives ...   Sep 30 2011, 07:12 PM
76-914   [quote name='mgphoto' post='1547261...   Oct 1 2011, 11:48 AM
mgphoto   I took the case over to Engine Machine Services, t...   Oct 5 2011, 01:27 PM
r_towle   Dont glass bead it, you wont see it after you buil...   Oct 5 2011, 01:35 PM
mgphoto   Dont glass bead it, you wont see it after you bui...   Oct 5 2011, 04:16 PM
mgphoto   OK dismantled the heads, there is one odd item, on...   Oct 12 2011, 06:22 PM
Vacca Rabite   That is an intake valve guide dropping into the he...   Oct 12 2011, 06:50 PM
mgphoto   That is an intake valve guide dropping into the h...   Oct 13 2011, 06:10 PM
mgphoto   OK got the case back after cleaning and tapping th...   Oct 13 2011, 06:13 PM
HAM Inc   That head with the dropping intake valve guide has...   Oct 13 2011, 07:03 PM
- Lo-Fi Version Time is now: 19th November 2026 - 12:55 PM
