Hey Brad, how's the Kitcarlson FI coming, Any progress on the replacement FI syste |
Rog914 |
Apr 2 2004, 10:27 AM
914 Fanatic Group: Members Posts: 129 Joined: 5-January 03 From: Reisterstown,Md Member No.: 93 |
It's been awhile and just wondering how the Kitcarlson FI system your testing is coming? It looks to be a good relacement for all are 914-4 engines. I know your very busy, just like to know how the testing is coming along.
Thanks for any info, Ralph 74 2.0 |
KitCarlson |
Apr 27 2004, 06:40 AM
Member Group: Members Posts: 85 Joined: 20-August 03 From: TN Member No.: 1,052 |
Mark, Brad,
The communications interface is 57,600b 8,n,1 no handshake, VT100 emulation, no echo. Commands: "t" to change modes, ">" to index value. "+" to increase, "-" to decrease. "s" to save "y" to comfirm. Test your port ny connecting pins 2 and 3 to loop back, Make sure you have the static timing set by having engine crank at 8deg and dist interruptor trailing edge on "A" sensor at center of sensor notch. Based on the picture you sent if crank was at 8 degrees you are about 30 degrees advanced at idle! Kit |
Lo-Fi Version | Time is now: 11th June 2024 - 01:14 AM |
