| ptravnic |
Sep 29 2011, 12:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None
I have the rear reflector and have drilled a small hole in the middle of the "S" that I can push a coat hanger (actually have a perfect sized allen wrench) through to manually release. The manual cable release don't work b/c I have a trailer hitch mount that would interfere with the cable routing.
I'd prefer to have an electric option that operates from the cockpit. Who sells the solenoid setup? Are there other solenoid's that can be customized to work? Thanks in advance! -pt |
| Steve73 |
Sep 30 2011, 06:37 PM
Photographer/Shade Tree Mechanic ![]() ![]() Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
I'm The SOL that everybody else is talking about! (IMG:style_emoticons/default/headbang.gif)
I got this car as a non runner as well. But now it starts (IMG:style_emoticons/default/smile.gif) The last time I had i running I meant to try hitting the button to see if it would have a little more juice and open. At one point I could hear it trying to open but after I crossed the wrong wires I hear nothing coming from the servo anymore (IMG:style_emoticons/default/sad.gif) BTW there seems to be no emergency cable release installed on this trunk (IMG:style_emoticons/default/sad.gif) This trunk hasn't been opened in over 5 years.....I wonder what it looks like inside, and what is in it? |
| jaxdream |
Oct 1 2011, 08:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I'm The SOL that everybody else is talking about! (IMG:style_emoticons/default/headbang.gif) I got this car as a non runner as well. But now it starts (IMG:style_emoticons/default/smile.gif) The last time I had i running I meant to try hitting the button to see if it would have a little more juice and open. At one point I could hear it trying to open but after I crossed the wrong wires I hear nothing coming from the servo anymore (IMG:style_emoticons/default/sad.gif) BTW there seems to be no emergency cable release installed on this trunk (IMG:style_emoticons/default/sad.gif) This trunk hasn't been opened in over 5 years.....I wonder what it looks like inside, and what is in it? Don't mean to hijack the thread , there seems to be some differing opinions about the subject of electical trunk release - not working well........ Steve , there was some threads back a few months on a method of opening the rr trunk when the solenoid failed . IIRC it descrbed the use of a long wire ( coat hangers together ??) and a flashlight . Basicaly reaching into the trunk with the wire to hook and pull the release. But if there is someting in the trunk in the way that would be a problem . Unbolting the trunk lid would be iffy when the hinges started to lift up from the force from the hinge bars and rollers , but may be an option. Good Luck.... Jack |
ptravnic Rear Trunk Release Solenoid - where to find one? Sep 29 2011, 12:27 PM
Rand You can have the one I removed from my car for the... Sep 29 2011, 03:02 PM
ptravnic
You can have the one I removed from my car for th... Sep 29 2011, 03:23 PM
proto31 I had a brand new one and never installed it b/c i... Sep 29 2011, 03:20 PM
76-914
I had a brand new one and never installed it b/c ... Sep 29 2011, 04:32 PM
ptravnic
I'd keep the stock setup or run a cable inste... Sep 29 2011, 07:45 PM
76-914 I can read reading, I just can't read writing. Sep 29 2011, 07:48 PM
ptravnic
I can read reading, I just can't read writing... Sep 29 2011, 08:30 PM
Bartlett 914 I never had any luck with that solenoid. The power... Sep 30 2011, 07:14 AM
Steve73 :Qarl:
Thank you so much jaxdream for visiting ... Oct 9 2011, 06:29 PM
jaxdream No problem dude , just glad it worked out . Had a ... Oct 9 2011, 07:24 PM
Brett W So what is so hard about finding a modern electric... Oct 9 2011, 08:42 PM
ptravnic
So what is so hard about finding a modern electri... Oct 9 2011, 09:33 PM
Brett W No ideas yet, was just thinking about my Wife... Oct 10 2011, 08:00 AM
majkos On the Green machine, I used a bike cable and cove... Oct 10 2011, 08:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 02:55 PM |
