TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I have a noise that sounds like its coming from the right rear. Its a noise that sounds like a high pitch pulsating car alarm, only not so loud. It starts about 15 mph and continues till its drowned out by my exhaust noise. It doesn't get louder and doesn't change pitch. The pulsating doesn't seem to change speed much with mph. It still present with clutch in and coasting so I believe its in the rotating part of the wheel. CV's have been replaced on that side. The wheel bearing was slightly loose but has since been properly tightened. Could the bearing have been ruined by the looseness?
All opinions welcome (I'll throw them out if I don't like them. LOL). Thanks. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE The wheel bearing was slightly loose but has since been properly tightened. How do you do that? There is no means or method for tightening a rear bearing. They go in and the nut gets torqued to 220lbft. If you meant that your stub axle was loose, this "may" have damaged the bearing. QUOTE I would have to bet on the wheel bearing. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 9th July 2025 - 01:39 PM |
