| Radmacdaddy |
Oct 3 2011, 06:46 AM
Member ![]() ![]() Group: Members Posts: 83 Joined: 28-September 11 From: United States Member No.: 13,617 Region Association: None |
Anyone who reads this and knows who it's from knows that I am in a time crunch. I will be with me new van in two days time, so will know more then, and could possibly answer this question myself...
anyway... I see pics of the heads being removed from a 70's vw van while the engine is in the van here: http://benplace.com/heads.htm So, my question is, is this also possible on a vanagon with the updated design... mine is a 1980. Finally, is there any reason I can't go further and remove the cylinders as well from there? Ultimately, I am thinking this is far quicker than my newbie self removing the engine, without all the tools at hand without having to build them or buy them (I'm $ crunched too (IMG:style_emoticons/default/wink.gif)) Thanks for any thoughts... this has been a great active forum! |
| TheCabinetmaker |
Oct 3 2011, 02:17 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Hmm, You say 1st gear is fine and 2nd bogs? sounds suspiciously like its in 4th and not 2nd. There is no reason I can "think" of that would make it bog in one gear and not another.
Radmacdaddy Pulling heads & cylinders from a VW Vanagon Oct 3 2011, 06:46 AM
type47 What do you suspect is wrong with the engine? I wo... Oct 3 2011, 07:25 AM
nathansnathan Up to '83, the engine is the air-cooled, just ... Oct 3 2011, 08:11 AM
aircooledtechguy While it *can* be done with the motor installed, i... Oct 3 2011, 08:31 AM
Radmacdaddy
While it *can* be done with the motor installed, ... Oct 3 2011, 01:31 PM
Cap'n Krusty A floor jack will work fine. You say you're s... Oct 3 2011, 01:56 PM
Radmacdaddy
A floor jack will work fine. You say you're ... Oct 3 2011, 02:02 PM
Radmacdaddy ok, here's a question...
The issue is: big lo... Oct 3 2011, 02:11 PM
r_towle
The issue is: big l... Oct 3 2011, 02:33 PM
vwsamba I had to laugh at your comment, these engines are ... Oct 3 2011, 09:35 PM
nathansnathan You are wrong.
The time it will take you to take ... Oct 3 2011, 02:19 PM
Radmacdaddy Really great advice everyone... I REALLY appreciat... Oct 3 2011, 02:58 PM
r_towle 1st gear on a vanagon will move alot of weight...2... Oct 3 2011, 03:10 PM
Cap'n Krusty Look at #3 before you do anything. Do a compressio... Oct 3 2011, 03:53 PM
Radmacdaddy
Look at #3 before you do anything. Do a compressi... Oct 3 2011, 09:55 PM
jcd914
would a rebuild with 30k erode a head like that?
... Oct 3 2011, 10:45 PM
Cap'n Krusty
Look at #3 before you do anything. Do a compress... Oct 3 2011, 11:51 PM
Radmacdaddy
I've seen 'em fail in less than a month ... Oct 4 2011, 10:49 AM
Cap'n Krusty
I've seen 'em fail in less than a month... Oct 4 2011, 12:22 PM
Radmacdaddy
[quote name='Radmacdaddy' post='1549160' date='Oc... Oct 4 2011, 01:09 PM
wingnut86 Cap'n, correct me if I'm wrong, but can... Oct 3 2011, 05:05 PM
Cap'n Krusty
Cap'n, correct me if I'm wrong, but can... Oct 3 2011, 05:20 PM
Radmacdaddy Ok, I'm getting the picture guys. Thanks.
I ... Oct 3 2011, 09:52 PM
r_towle I would honestly suggest that you go see John and ... Oct 4 2011, 10:51 AM
Radmacdaddy
I would honestly suggest that you go see John and... Oct 4 2011, 01:08 PM
type47 Yea, but maybe not on cars in states other than CA... Oct 4 2011, 01:11 PM
Cap'n Krusty The EGR plumbing goes to the intake plenum, not th... Oct 4 2011, 01:59 PM
type47 How does that cool the heads? 'Splain that to ... Oct 4 2011, 02:42 PM
Cap'n Krusty It adds exhaust gasses to the cylinder charge, red... Oct 4 2011, 07:40 PM
Radmacdaddy I HAD to do it!!
And it hasn't been b... Oct 9 2011, 07:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:55 AM |
