> Pulling heads & cylinders from a VW Vanagon, ...can it be done without pulling the engine?
Radmacdaddy
post Oct 3 2011, 06:46 AM
Anyone who reads this and knows who it's from knows that I am in a time crunch. I will be with me new van in two days time, so will know more then, and could possibly answer this question myself...
anyway... I see pics of the heads being removed from a 70's vw van while the engine is in the van here: http://benplace.com/heads.htm
So, my question is, is this also possible on a vanagon with the updated design... mine is a 1980.
Finally, is there any reason I can't go further and remove the cylinders as well from there?
Ultimately, I am thinking this is far quicker than my newbie self removing the engine, without all the tools at hand without having to build them or buy them (I'm $ crunched too (IMG:style_emoticons/default/wink.gif))
Thanks for any thoughts... this has been a great active forum!
Cap'n Krusty
post Oct 3 2011, 03:53 PM
Cap'n Krusty
Look at #3 before you do anything. Do a compression test. These things like to drop valve seats and drop valves. They also erode the edge of the piston, right down to the top ring groove, and I think you're gonna find the top end is toast. I don't think you can remove that wrist pin with the #4 piston and cylinder in place. Personally, I think you're just being stubborn. There's no way I'd even attempt this in the car, and I've been working on T2s and Vanagons since 1973. Never crossed my mind to do it in the car .....................
The Cap'n,
Radmacdaddy
post Oct 3 2011, 09:55 PM
QUOTE(Cap'n Krusty @ Oct 3 2011, 05:53 PM) *
The Cap'n,
would a rebuild with 30k erode a head like that?
I'm not being stubborn Cap'n, just being sure that's what's ahead of me, and appreciate your advice fer sure. well, ok... I have known to be stubborn. (IMG:style_emoticons/default/wink.gif)
Thanks!
Radmacdaddy   Pulling heads & cylinders from a VW Vanagon   Oct 3 2011, 06:46 AM
type47   What do you suspect is wrong with the engine? I wo...   Oct 3 2011, 07:25 AM
nathansnathan   Up to '83, the engine is the air-cooled, just ...   Oct 3 2011, 08:11 AM
aircooledtechguy   While it *can* be done with the motor installed, i...   Oct 3 2011, 08:31 AM
Radmacdaddy   While it *can* be done with the motor installed, ...   Oct 3 2011, 01:31 PM
Cap'n Krusty   A floor jack will work fine. You say you're s...   Oct 3 2011, 01:56 PM
Radmacdaddy   A floor jack will work fine. You say you're ...   Oct 3 2011, 02:02 PM
Radmacdaddy   ok, here's a question... The issue is: big lo...   Oct 3 2011, 02:11 PM
r_towle   ok, here's a question... The issue is: big l...   Oct 3 2011, 02:33 PM
vwsamba   I had to laugh at your comment, these engines are ...   Oct 3 2011, 09:35 PM
vsg914   Hmm, You say 1st gear is fine and 2nd bogs? sounds...   Oct 3 2011, 02:17 PM
nathansnathan   You are wrong. The time it will take you to take ...   Oct 3 2011, 02:19 PM
Radmacdaddy   Really great advice everyone... I REALLY appreciat...   Oct 3 2011, 02:58 PM
r_towle   1st gear on a vanagon will move alot of weight...2...   Oct 3 2011, 03:10 PM
Cap'n Krusty   Look at #3 before you do anything. Do a compressio...   Oct 3 2011, 03:53 PM
Radmacdaddy   Look at #3 before you do anything. Do a compressi...   Oct 3 2011, 09:55 PM
jcd914   would a rebuild with 30k erode a head like that? ...   Oct 3 2011, 10:45 PM
Cap'n Krusty   Look at #3 before you do anything. Do a compress...   Oct 3 2011, 11:51 PM
Radmacdaddy   I've seen 'em fail in less than a month ...   Oct 4 2011, 10:49 AM
Cap'n Krusty   I've seen 'em fail in less than a month...   Oct 4 2011, 12:22 PM
Radmacdaddy   [quote name='Radmacdaddy' post='1549160' date='Oc...   Oct 4 2011, 01:09 PM
wingnut86   Cap'n, correct me if I'm wrong, but can...   Oct 3 2011, 05:05 PM
Cap'n Krusty   Cap'n, correct me if I'm wrong, but can...   Oct 3 2011, 05:20 PM
Radmacdaddy   Ok, I'm getting the picture guys. Thanks. I ...   Oct 3 2011, 09:52 PM
r_towle   I would honestly suggest that you go see John and ...   Oct 4 2011, 10:51 AM
Radmacdaddy   I would honestly suggest that you go see John and...   Oct 4 2011, 01:08 PM
type47   Yea, but maybe not on cars in states other than CA...   Oct 4 2011, 01:11 PM
Cap'n Krusty   The EGR plumbing goes to the intake plenum, not th...   Oct 4 2011, 01:59 PM
type47   How does that cool the heads? 'Splain that to ...   Oct 4 2011, 02:42 PM
Cap'n Krusty   It adds exhaust gasses to the cylinder charge, red...   Oct 4 2011, 07:40 PM
Radmacdaddy   I HAD to do it!! And it hasn't been b...   Oct 9 2011, 07:07 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:58 AM
