> turbo tie rods, do the ball joints bend?
7391420
post Apr 27 2004, 02:57 PM
I just recieved a new set of the Lemforder turbo tie rods and after taking them out of the packaging, the ball joint at the end is bent-IE the rod is not flat. I am assuming that the ball joint is just rotated a bit, but I cant straighten it by hand so I'm wondering if this is normal, and when installing, it will straighten???
post Apr 27 2004, 03:11 PM
Paul,
Thanks, it's actually the other end of the tie rod, which looks like a ball and socket-
to me it looks as if you should be able to rotate it, and so maybe when they were built they just were not put on straight, but I can't rotate the ball joint by hand to straighten it so I just wondering if this is normal, or a part defect..
- Lo-Fi Version Time is now: 1st July 2025 - 03:43 PM
