| kconway |
Oct 4 2011, 07:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I've got a Carter fuel pump and I'm trying to find a place to locate it. I was thinking there would be room up under the car where the steering rack is but I looked there but can't imagine where I could put it. Not real comfortable with cutting open an access hole where the later cars had them located.
Any good ideas in these photos? ![]() ![]() ![]() Kev |
| GeorgeRud |
Oct 5 2011, 01:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Take off the cover that shields the steering rack, and you should be able to fit the pump next to the rack. This will save you from having to cut holes in the front trunk, and if a leak would develop, it would just drain onto the ground.
Also, the cover will protect the pump but still have it serviceable. Since the fuel lines are already there, why not? |
kconway Looking For Advice Oct 4 2011, 07:01 PM
76-914 Maybe this will help:
The grommets came from a ... Oct 4 2011, 07:14 PM
kconway
Take off the cover that shields the steering rack... Oct 5 2011, 04:56 PM
Grelber +1 Mine is that same one, and it's underneat... Oct 5 2011, 02:47 PM
Krieger You could put it up about 1' from where it is ... Oct 5 2011, 05:26 PM
gothspeed
You could put it up about 1' from where it is... Oct 10 2011, 12:23 PM
kconway This is where mine ended up. I drilled the two ho... Oct 10 2011, 01:23 PM
gothspeed Looks good! I like how you used the line betwe... Oct 10 2011, 02:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 12:26 AM |
